Electric Furnace Blowing Breaker - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-13-2010, 09:21 AM   #16
Rewards Points: 152
Sorry I didn't mention, the filter is brand new and the blower motor doesn't seem to be making any unusual noises or have anything bound up inside it.
burnt03 is offline   Reply With Quote
Old 01-13-2010, 09:45 AM   #17
OK time to open up the electrical panels on the heater and look at all the wiring and check all connections for loose ness(is that a word?) .Also look for burnt wires.
AFTER YOU SHUT OFF THE MAIN POWER.
SULTINI is offline   Reply With Quote
Old 01-13-2010, 11:00 AM   #18
let us know what happens my vote is still on the breaker
kennzz05 is offline   Reply With Quote
Old 01-13-2010, 11:52 AM   #19
Need an amp meter. Not voting until then.
Old 01-13-2010, 12:02 PM   #20
he has one, 85 amps on a 125 brkr
Old 01-13-2010, 12:07 PM   #21
Thanks Kennzz05, must have failed reading missed the 85 I vote with Kennzz05.
Old 01-13-2010, 02:11 PM   #22
Rewards Points: 152
Connections all seemed fine, didn't see or smell any burnt wires/connections.
I'll try changing out the breaker, probably won't know if it works for a while though, problem is very intermittent.
I'll let you know!
Old 02-05-2010, 02:27 AM   #23
Rewards Points: 152
Changed the breaker a couple of weeks back and all seems well.
A fellow that does instrumentation work for us is an electrician and offered to buy the breaker for me, little bit cheaper that way. He happened to be in town so came over and looked and found quite a few problems.....
20A breakers where 15A breakers should have been
30A breakers running two appliances (220V hot water heater, 220V dryer, etc)
There was a single pole 40A that he took out, I'm not sure what that was supplying
So, all is said and done, have a new 125A breaker, 3 new 30A breakers and the peace of mind to know that it's as it should be. The breakers below the 125A seemed a bit loose on the panel, he said it was possible that the heat that was generating was moving up and causing false trips.
Thanks for all the tips, hopefully this'll solve it!
Old 01-04-2011, 01:10 AM   #24
Burnt wiring in electric forced air furnace
I just checked my furnace today, and found this, as you can see the panel is burnt, Time to call an electrician, Is it safe to run the furnace with this wiring issue in the inturm??
bremax is offline   Reply With Quote
Old 01-04-2011, 05:12 AM   #25
An old Tradesmen
Rewards Points: 6,590
Not really. The wire will burn up more as its used. May need an HVAC tech, to find out why its burning. Many electricians don't get involved with electric air handlers.
Old 01-04-2011, 07:22 PM   #26
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
is that limit switch shorted causing the overheating of the wire?
plummen is offline   Reply With Quote
Old 01-04-2011, 09:36 PM   #27
Are these heating coils that are burnt, I hope this wont be a costly fix
Old 01-04-2011, 09:50 PM   #28
An old Tradesmen
Those are the thermal limits that have the burnt wires. Depends what caused the burnt wires, as to how expensive the repair is or isn't.
new electric water heater - Vacuum breaker necessary? J187 Plumbing 12 05-26-2012 09:42 AM
Electric furnace makes loud noise like a breaker when it starts?? epyke HVAC 5 10-13-2009 06:03 PM
New electric dryer is blowing breaker! minameismud Electrical 7 09-14-2008 11:45 PM
electric furnace help nikko4 HVAC 2 11-13-2007 08:43 PM
60 Amp Electric Furnace AverageJoseph Electrical 13 06-22-2007 08:49 AM
