Electric Furnace Blowing Breaker - HVAC - DIY Chatroom Home Improvement Forum
Old 12-23-2009, 09:20 AM   #1
Rewards Points: 152
Electric furnace blowing breaker
Have an American standard electric furnace.
Couple times over the past month I've woken up and the furnace hasn't kicked in. Further check shows that the breaker (in the box) has blown.
I'm a rook so excuse the questions, but where should I start first?
Thanks in advance!
burnt03 is offline   Reply With Quote
Old 12-23-2009, 09:46 AM   #2
HVAC Tech/ Browns Fan
You need to check the temp on breaker. If its hot then you may have heating elelments going bad but if not hot it can just be a bad breaker. I like to say at this time please call the pro's
Tator1076 is offline   Reply With Quote
Old 12-23-2009, 07:40 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,396
You need to get it checked by a licensed service electrician or heating tech ASAP. You may have bad connections inside and they WILL overheat, arc/spark and the wiring can melt and smoke and if left long enough start on fire. Seen quite a few roasted electric furnaces in my career.
Old 12-23-2009, 09:42 PM   #4
Originally Posted by burnt03 View Post
I've woken up
If it took hours for the breaker to trip you may be looking for a very mild overload or bad breaker connections.
Old 12-24-2009, 08:15 AM   #5
An old Tradesmen
Rewards Points: 6,464
Originally Posted by filtersupply View Post
The world's no.1 filter manufacturing and distribution company
If you wish to purchase advertisement. Use This
No free advertising
Old 01-11-2010, 07:46 PM   #6
Rewards Points: 152
Did it again last night, tried calling a tech today. No one available that's familiar with electric furnaces, but the guy said that the first thing they'll do is change the breaker.
As a side note, the two 60A breakers on the furnace have never tripped on me (I assume one for each stage), only the main 125A one.
I took the clamp on multimeter home from work and read approximately 80A running through the feed wires at first start-up and during regular operation. The connections at the breaker are tight and it doesn't seem to be getting very warm.
I guess I'll try changing the breaker and if that doesn't work, have to wait for a tech to check it out.
Old 01-11-2010, 07:49 PM   #7
If you are tripping the Main 125a breaker then it is either:
Main breaker is failing
OR You are exceeding the 125a capacity
What else in your house uses electricity ?
You have (2) 60a feeds for electric heat & only a 125a Main panel ?
Old 01-11-2010, 10:48 PM   #8
Rewards Points: 152
Hi Scuba,
Sorry I wasn't more clear.
I have a 200A service to the house. The electric furnace has a 125A breaker switch. On the furnace itself is a small hatch, behind it being (2) 60A breaker switches. It is the 125A breaker specifically for the furnace that is tripping on me.
Like I mentioned, I had a gauge on the amperage draw on startup (which I assumed to be where the most draw will occur?) and it doesn't get much higher than 85A. So unless there's a short that occurs at a different part in the cycle, it doesn't seem to be exceeding the 125A.
Old 01-12-2010, 02:35 AM   #9
sounds like youre on the right track suspecting the breaker. im suprised they didnt run 2 circuits to the furnace.
kennzz05 is offline   Reply With Quote
Old 01-12-2010, 06:18 AM   #10
An old Tradesmen
Did you check the amp draw at the air handler. Or at the 125 amp panel box?
Old 01-12-2010, 09:14 AM   #11
Rewards Points: 152
At the panel box. Are you thinking there might be a problem with the wiring between the 125A breaker and the (2) 60A breakers in the handler? I'll have to check that after work.
On the bright side, it didn't kick off last night
Old 01-12-2010, 11:36 AM   #12
Could be a bad connection to the breaker which causes heating at the connection.
Old 01-12-2010, 10:51 PM   #13
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
motor making noise,filter clogged? check simple things first.
plummen is offline   Reply With Quote
Old 01-13-2010, 07:59 AM   #14
Yeah simple things first then amp readings then solution.
Oh sorry it's back wards first open heater and look around real good and check all connections then proceed to our suggestion.
SULTINI is offline   Reply With Quote
Old 01-13-2010, 09:00 AM   #15
plummen's Avatar
how about checking obvious stuff before the guy starts replacing circuit breakers? like a filter that hasnt been changed in months cusing no air flow across motor or heat exchanger,or a filter wrapped up in the motor causing an overload.definately dont check simple things first!
new electric water heater - Vacuum breaker necessary? J187 Plumbing 12 05-26-2012 09:42 AM
Electric furnace makes loud noise like a breaker when it starts?? epyke HVAC 5 10-13-2009 06:03 PM
New electric dryer is blowing breaker! minameismud Electrical 7 09-14-2008 11:45 PM
electric furnace help nikko4 HVAC 2 11-13-2007 08:43 PM
60 Amp Electric Furnace AverageJoseph Electrical 13 06-22-2007 08:49 AM
