Electric Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 01-16-2012, 08:12 PM   #1
electric furnace
I have a old furnace that was taken out of a shop. I don't know what size it is. It was working fine when it was removed but it has been stored for about a year. I would like to install it in my shop. I would like to replace the wires just to be safe some of them look pretty bad. I don't know a good HVAC person. I looked on line to find a wiring diagram but could not find one. It has a heavy wire connected to -red, black, white and green. When I removed the cover the white wire was not connected to anything. some wires had wire nuts on them but were not connected to nothing. I guess I need to know if this is going to be a headache or if its worth installing. Any help would be greatly appreciated. Thanks
danno70207 is offline   Reply With Quote
Old 01-16-2012, 08:25 PM   #2
biggles's Avatar
sounds like 230V with that black/red wire is it resistance elements with a supply fan to blow out into duct work? any chance for brand,model maybe a picture..very risky not knowing your electrical service,and the state of the elements if it's not gas furnace...is it going into a garage?
Old 01-20-2012, 06:25 AM   #3
It is a electric furnace. The elements look fine. My service in the shed consist of a small sub pannel with 2- 20 amp breakers 1-30 amp RV hook-up and 1-20amp GFI for a pool. I will try to get some pics and post.
Old 01-20-2012, 08:03 AM   #4
biggles's Avatar
is that panel 230V feed from the house or is all that 115V breakers and if there is room for a 230V breaker
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Electric Furnace Sammy 2 Electrical 2 11-20-2011 08:22 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
electric furnace need help Unregistered HVAC 3 10-16-2007 02:41 AM
