Effect Of Heat Load Of Tenants On A Commercial Building - HVAC - DIY Chatroom Home Improvement Forum
Old 04-20-2011, 01:30 AM   #1
Effect of Heat Load of Tenants on a Commercial Building
I need to know how much effect of a tenant store inside a commercial building in terms of cooling load.
The building employs a centralized air-conditioning ( cooling tower, water-cooled chillers, AHU etc). Say a particular AHU distribute conditioned air to cool 10 tenant stores by duct system. How much effect on the cooling load of the building if 3 tenant stores, serve by that AHU, egress and their stores was boarded up and the diffusers were sealed. Note that the stores are using supply diffusers and ceiling return.
Is it right to say, I am still giving 100% cooling load of the building, regardless of the unoccupied tenant stores?
Will a boarded up unoccupied store generates heat that the centralized AC needs to compensate?
I will highly appreciate all inputs on this situation.
mphoenix is offline   Reply With Quote
Old 04-20-2011, 03:59 AM   #2
An old Tradesmen
Rewards Points: 7,816
The unoccupied spaces will still have a heat gain during the day. But you can set the thermostats to off or 90 to prevent any unnecessary cooling of those spaces.
Generally, stores only have a full load for cooling during their busiest sales time.
Is this a VAV or CAV system.
Sizing a Heat Pump for a simple building choffman HVAC 3 07-25-2010 10:59 PM
Aux heat doesn't come on during defrost cycle hesse HVAC 5 03-18-2010 04:10 AM
Building Cabinets over heat pipes WaldenL Carpentry 2 01-26-2009 02:10 PM
Metal Building Heat buzzurd HVAC 20 10-19-2008 12:50 PM
Commercial heat tape. rforsha Electrical 3 12-04-2007 07:41 PM
