Old 12-08-2009, 06:31 PM   #1
Still Learning
Economizer
I need a little clarification. I know that the economizer is placed on the return duct to draw in outside air. Why is this necessary? My best guess is that if a building is completely sealed off you would need outside air so that people can breath. Is that the case or are there other purposes for an economizer?
thehvacguy is offline   Reply With Quote
Old 12-08-2009, 07:04 PM   #2
An old Tradesmen
Economizer
An economizer. is to provide free cooling during those times of the year that the outdoor air is cool enough. But the building heat load still requires heat.
Usually a min opening can be set for a constant fresh air. As required by building codes. To dilute/remove CO2 build up.
