ECM Blower Motor Whine - HVAC - DIY Chatroom Home Improvement Forum
Old 12-11-2010, 10:22 AM   #1
Rewards Points: 163
ECM blower motor whine
The blower motor on my new Trane XV95 gas furnace makes a discernible high pitched whining noise when it's getting up to speed or slowing down. It sounds like a jet plane engine winding up or shutting down only not as loud, of course. Is this typical for these ECM motors? Once up to speed the noise goes away. My installer seemed to think it was a normal sound. They checked the motor and its mounting and found nothing abnormal. I guess I can live with it but I don't like it.
Was wondering what others have experienced with these ECM motors. Appreciate any comments. Thanks.
kb3ca is offline   Reply With Quote
Old 12-11-2010, 10:32 AM   #2
AKA HVACTECHFW
Rewards Points: 1,208
ECM motors are normally very quiet. Is the noise from the motor? Is it transmitting through an AM radio?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 12-11-2010, 10:48 AM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 388
As long as they did a temp rise test on BOTH stages and it is within specs it should be okay. Lots of them are running too fast or slow. Trane does not know what your ducts look like or their size so it should be properly setup in the home.
Old 12-11-2010, 10:55 AM   #4
Rewards Points: 163
The noise seems to be coming from the motor. Used AM radio at low end of the band and didn't hear anything related to the motor spinning. I'm familiar with that technique and tuned around to make sure. I'm just wondering if that is a characteristic of those type motors. Hoping some others can let me know if they hear anything.
Old 12-11-2010, 11:00 AM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 388
Have never heard one whine and we sold several thousand of them in Lennox units.
Old 12-11-2010, 11:02 AM   #6
Rewards Points: 163
They did check the temperature rise in both stages and it is within spec. They did run the blower with the door off to listen to the motor but the sound was the same. Not extremely loud, just a little annoying during ramp up and down.
Old 12-11-2010, 11:05 AM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 388
Sounds normal to me, they do have a sound when ramping and that is normal. They rock a bit on startup also and make some noise. Try run it continuos and see if you like that. LOTS of my customers love that. Usually only blows about 400 cfm on low and the motor has ball bearings and is designed for continuos use.
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 04:39 PM
Blower shuts off even when set to 'on' fetzer85 HVAC 1 07-05-2010 11:48 AM
Trane Furnace Blower Running Nearly Continuously stephensandlin HVAC 3 01-03-2010 01:21 AM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 09:09 PM
AC blower short cycling-works on heat though Steve60007 HVAC 14 06-22-2009 04:00 PM
