ECM Blower Motor Bad - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-13-2011, 10:43 PM   #16
Originally Posted by beenthere View Post
Plus, you still need to fix the poor air flow of your duct system. Since thats what took out the module.
Good point. If I may ask what are some things to look for to determine the cause of the poor airflow aside from the filter which I change regularly? Thanks in advance and thanks for your help so far!
Dragons Den is offline   Reply With Quote
Old 02-14-2011, 03:42 AM   #17
An old Tradesmen
Rewards Points: 8,202
The duct system itself. Post the sizes of your return an d supply ducts. They are most likely too small. Could also have crushed duct work, or kinks in the duct.
What size unit was there before the Coleman.
The Following User Says Thank You to beenthere For This Useful Post:
Dragons Den (02-21-2011)
Old 02-14-2011, 06:57 AM   #18
Rewards Points: 516
Most interesting relevant post about variable speed fans. Worth a look:
Carrier 58MVP Blower Problem
diyorpay is offline   Reply With Quote
Old 02-21-2011, 11:39 AM   #19
16". That all checked out when I went from a 1T to 3T A/C Unit. I had an electrician buddy of mine come out and the breaker for the A/C unit was going bad, think maybe that fried the thermistor?
To update: I finally received the new thermistor three days ago and soldered it in and tried the fan motor. While it now will turn on it slows and speeds repeatedly every few seconds so it's probably bad. I bought a PSC motor and am just going to go that route.
Old 02-21-2011, 03:56 PM   #20
An old Tradesmen
The slowing and speeding up is from under sized, restricted duct, or too many closed or covered up registers/grilles.
A single 16" flex duct is border line for 3 tons. A static pressure test will tell you how bad your duct work is or isn't.
Old 11-23-2013, 12:13 PM   #21
My ECM motor was making horrible noises. It was still working but the house was taking 3 times as long to heat up. I took the ECM out and took off the back plate and noticed a ton of dust. Like my computer I blew off all the dust and it resumed working. I believe the electronics were confused by all the dust. I later saw in the manuel that every year I am supposed to vacume it out once a year.
I hope that helps someone.
I also had a small water leak and tightened my condensation tubes
then I had and no more leak.
Thanks to all the other posts (from other sites too) this gave me all these ideas so I didn't have to make call to the repairman. I hope this helps someone.
wyoming is offline   Reply With Quote
Old 01-04-2014, 07:21 PM   #22
hvac thermistor 379 replacement
I have a bunch of SG405 thermistors that replace Sg379 Thermistors
I sell them for ten bucks a piece call 800-584-1892 leave a message I I will
send one to you for 10.00 plus the price of a stamp.
sammyy125 is offline   Reply With Quote
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 04:39 PM
Heat comes on but blower never does aczer HVAC 12 02-13-2011 06:57 AM
Blower cycling and vibration whatshappening HVAC 1 02-09-2010 04:48 AM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 09:09 PM
AC blower short cycling-works on heat though Steve60007 HVAC 14 06-22-2009 04:00 PM
