Easy Seal/ Super Seal - HVAC - Page 7 - DIY Chatroom Home Improvement Forum
Old 09-19-2013, 04:27 PM   #91
An old Tradesmen
Rewards Points: 8,194
Originally Posted by sublime2 View Post
Because it's so predictable that an HVAC guy would say the chances are slim to none that it will work even after the opposite has been stated.
All of us are happy it currently appears to be working form him. And all of us hope he continues to post yearly updates of how his system is working.
As contractors, many of us have seen the problems from when it didn't work. Or it only held the customer over for a year or 2. And then required more work to replace the system.
Hopefully he will continue to give us updates.
Old 09-19-2013, 10:32 PM   #92
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Originally Posted by Patrick Eubanks View Post
I always love coming to this site and seeing folks from New Jersey bash the ethics of the HVAC contractors who come here to help the DIY ers.
Classy!
You may want to re-read what I said.
I didn't "bash the ethics "of anyone!
sublime2 is offline   Reply With Quote
Old 05-26-2014, 05:10 PM   #93
2014 UPDATE. Due to the much colder than normal temps in the northeast so far this year, its only really today with temps of near 90 that I can finally test my Trane 23 year old (or so) central air system after a hvac tech installed "Super Seal w/dryer" to fix a slow freon leak at the evaporator coil, about 2 years ago.
I can say that at this time the A/C is working just as it has the past 2 summers, cuts the the humidity and brings down the temperature within approx the same amount of time . There are no strange sounds or any abnormal actions that I can notice from the compressor. The fat line is still dripping wet /cold and the the small line is warm to the touch.
My original goal, since the system is so old, was really hoping to get 3 more summers of use , and so far, so good on this goal.
ea0680 is offline   Reply With Quote
Old 05-26-2014, 06:27 PM   #94
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Awesome!
Old 04-18-2015, 03:21 PM   #95
Rewards Points: 48
Originally Posted by tampaite View Post
Hello. Any update on how your A/C is working now?
Am also considering using A/C Sealant to fix minor leaks in the Evaporator coil.
April 2015 Update. The Cliplight Super Seal Advanced 944KIT worked for 2 years and now am having to replace the entire Bryant evaporator coil since it no longer works.
I bought another can but it didn't work since the leak is probably bigger.
My suggestion is, if you have 10+ yr old A/C unit then try this before replacing it.
tampaite is offline   Reply With Quote
Old 04-18-2015, 05:07 PM   #96
An old Tradesmen
Which begs the question. Did it save you money, or cost you more money since a new coil today, will cost more then it would have 3 years ago.
Old 04-18-2015, 05:24 PM   #97
Rewards Points: 48
Actually cheaper - previous evaporator coils were made of copper but these days they are made of aluminium and less prone to leaks!
Old 04-18-2015, 05:28 PM   #98
An old Tradesmen
They are less prone. But seldom cheaper.
Old 04-18-2015, 06:19 PM   #99
Rewards Points: 8,230
The superseal could have saved him from getting a copper coil and having another leak.
user_12345a is online now   Reply With Quote
Old 04-18-2015, 06:46 PM   #100
An old Tradesmen
Possible.
Old 04-18-2015, 06:53 PM   #101
Hvac Pro
yuri's Avatar
Rewards Points: 396
Copper coils have been around 4 ever. Problem is they went thin on some of them. Some are very good. ADP coils are exellent. Aluminum is a soft metal and from vibration can leak easier than copper and cannot be repaired.
All depends on the manufaturers preference. Like Trane and their goofy spine fin coils. Some people like them and some heat em.
Old 04-18-2015, 07:38 PM   #102
Update From 7/2012 Super Seal install. Its hard to believe so much time has passed already. Anyway, my original goal of 3 summers had been met, I am looking to see if I can get lucky and push it one more summer. So today, with northeast temps finally high enough to test out the now 24 year old trance A/C. .
I am happy to report that so far, even though not tested in 90 degree weather, the cold air did bring down the house temp in the usual time as prior years. Condensor big line is cold, wet. Compressor sound seems like normal, nothing strange. So if lucky, I will should get another summer out of unit.
I will note that the end of last summer, my condenser fan did not turn on, causing the compressor to run hot before I caught the problem and shut A/C down. My hvac service guy found the problem was faulty contact and replaced it, along with fan capacitor (it tested on the border line). So I am really hoping this compressor can make it over the finish line. Will update status again end of summer.
Old 04-19-2015, 09:05 AM   #103
Sounds like hit or miss with this stuff - definitely worth trying in old systems that aren't worth fixing properly.
Old 06-12-2015, 12:23 AM   #104
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Thank you for your dedication in keeping us updated over the past three years.
Very happy to hear the superseal performed so well for you!
Old 08-05-2015, 12:48 PM   #105
Rewards Points: 2
I use super seal
I have used super seal for a long time and have had no bad experience with it on only slow leaks. The ones that leak a Lb or two a year.
in order to meat EPA requirements YOU! half to do something to keep your but out of jail with a sealer YOU have made an attempt to stop the leak and you are compliant. Again I have had no bad experience with it.
good luck
damnitbill is offline   Reply With Quote
Bosch Dishwasher leaking along bottom seal of door mtbdudex Appliances 14 10-13-2012 08:49 AM
Anchor Seal Leaching on IPE rocketdoctor Building & Construction 5 09-07-2010 09:46 AM
About to lose it w/toilet seal schnitz411 Plumbing 11 05-27-2010 06:56 PM
do I need to seal tiles, and if so, when...? rtoni Tiling, ceramics, marble 5 03-26-2010 09:41 PM
to seal or not to seal the carpenter Flooring 3 03-15-2010 10:26 PM
