E-4 Error Code - HVAC - DIY Chatroom Home Improvement Forum
Old 07-19-2009, 09:20 AM   #1
E-4 error code
this is a Soleus Air--portable a/c mod#PE-2-09R-32. runs ok for about 20 minutes, then shuts down with that code.-????? anybody know what it means?-not overfilling and airflow is ok....Thank's.
Jacques is offline   Reply With Quote
Old 07-19-2009, 09:27 AM   #2
The flash codes should be listed on the ac or the in your paperwork,
hvaclover is offline   Reply With Quote
Old 07-19-2009, 09:52 AM   #3
it's not in the owners guide. it's for a friend. when i go there i'll look on a/c. he called the Co. they wouldn't tell him-?- they said to call a servicer. i don't service these but thought i'd ask you guys. Thank's, H.
Old 07-19-2009, 10:01 AM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 1,452
Is the internal air filter clean? Lack of airflow may freeze it up in 20 mins.
http://www.sylvane.com/images/prodph..._09-manual.pdf
There is a tech support phone number at the end of that file and a website.
Tell em you own "Jacques small appliance repair co" if they ask if you are a contractor,
Good Luck
Old 07-19-2009, 10:12 AM   #5
newtech's Avatar
Rewards Points: 164
What should I do if my unit has an E-4 problem?
The broken water tank flipper will directly cause the unit to not function and the E-4 message will appear on the display screen
This was from there web site. Good luck
newtech is offline   Reply With Quote
Old 07-19-2009, 11:38 AM   #6
Thank's much for the reply's. H.
