Dynamic Air Filter - Worth It? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-28-2011, 08:58 PM   #1
Rewards Points: 590
Dynamic Air Filter - Worth it?
This house we bought has a Dynamic Air Filter on each of the 3 air handlers.
Supposedly electrostatically attracts dust to its carbon fiber center.
Do these really work is it a mostly marketing BS?
Just wondering if I should pony up 50 bucks for 3 replacement filters......
noone is offline   Reply With Quote
Old 07-28-2011, 09:47 PM   #2
Rewards Points: 6,652
They are great if you have allergies. As for the cost of the filters, shop around. Now if you decide to disable the actual unit, and want to use regular filter media, you would have to use media that is wide enough to be placed inside the unit. Costs varies.
Old 07-28-2011, 10:23 PM   #3
Rewards Points: 590
Can you PM me some recommended (cheap) vendors?
Old 07-28-2011, 10:31 PM   #4
There are a few out on the web. If you post the model #, dimensions of current filter size (height, width, length), there are a couple of guys on here that will let you know specifics of which type of hepa will fit, if you do not want to continue to run as an electrostatic unit.
Old 07-29-2011, 01:05 PM   #5
Rewards Points: 590
I know 2 of the 3 units take 20 x 20 x 1. Not sure of the other one offhand.
I'd be interested in reliable cheap vendors that sell good hepa and/or Dynamic refills.
Old 07-29-2011, 05:06 PM   #6
AKA HVACTECHFW
Rewards Points: 1,208
Dynamic filters are great as long as you change the dang thing on a monthly or bi-monthly basis.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 07-29-2011, 05:12 PM   #7
Rewards Points: 590
The cheapest source I have found online is 46 bucks for 3 20x20x1 Dynamic Filters. Any cheaper places you know of?
Inground pool and filter...HELP! Blpavlovich Building & Construction 2 06-09-2011 05:49 PM
installing whole house filter on outside of house MikeInFL Plumbing 3 06-12-2010 04:47 PM
Trane whole house filter - Is it worth the money? Leoskee HVAC 4 03-25-2010 12:17 PM
Worth the Switch to Metal/Permanent Air Filter? wallix HVAC 3 01-12-2009 05:35 PM
Bypass Humidifier goes before or after air filter? key1cc HVAC 9 12-30-2008 09:12 AM
