Dusty House. What Is The Cause? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-14-2010, 09:02 PM   #1
Dusty house. What is the cause?
We seem to be dusting every couple of days in our 6 yr old house. What could the cause be? I noticed some dust around the furnace, thought it was sawdust but cant figure out where it is coming from. Opened one of the round access points for the ac?? and noticed some sediment inside the furnace. Is this what is causing all of the dust in the house? How do i clean the ac coils in the furnace?
hope the pictures help.
Thanks!
Dusty house. What is the cause?-furnace7.jpg   Dusty house. What is the cause?-furnace1.jpg   Dusty house. What is the cause?-furnace2.jpg
titaniumring is offline   Reply With Quote
Old 11-15-2010, 06:27 PM   #2
An old Tradesmen
Rewards Points: 6,160
Check your return ducts and grilles. If the return is leaky. Able to pull air from unconditioned space, it will draw in dust.
Old 11-15-2010, 06:41 PM   #3
Dust or sawdust ?
If its little powdery wood look overhead for signs of termites/bugs
Old 11-16-2010, 05:58 PM   #4
No insect problems that I could see. The pictures may show sawdust from work done in basement. Our house just seems way too dusty for a new house.
Old 11-16-2010, 10:22 PM   #5
30 year tech
hvac122's Avatar
As said the dust is most likely comming from leaky ducts or house. Most dust comes from the attic or outside through infiltration. You house needs to breath and if it gets into a negitive pressure the air will come in from wherever it can. I would have the house checked for leakage and do some sealing.
The air distribution system often gets blamed for the dust but it is only moving the dust around in most cases as it is already in the air. A good filtration system will help some with this. Where are the furnace and ducts in your house?
hvac122 is offline   Reply With Quote
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 08:18 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
New house drywall DISASTER pharm07 Off Topic 13 03-25-2011 03:24 PM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 11:09 PM
