Duo-Therm 86505 Nozzle Confusion? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-05-2010, 05:06 AM   #1
I have a Duo-Therm Mobile Home Furnace Model #86505 that I am trying to get running in my garage. I am having problems located the correct nozzle for a replacement. The furnace has a label which makes reference to the part #H2988 and also states the flow rate of .60 G.P.H. The current nozzle is a Delavan that says "hollow" and also gives two numbers: 181 and 6601. If I understand correctly I need to know three pieces of information when choosing a replacement nozzle: the flow rate, the angle of spray, and shape of the spray. The furnace gives me the .60 G.P.H. and the nozzle is labeled hollow, but I am unsure of the angle. I read that it is important to have the correct nozzle and would rather not use trial and error. I have the manual, but it only gives the same info that is printed on the furnace. Any help would be appreciated. Thanks, Sean
sjb49938 is offline   Reply With Quote
Duo Therm Oil Furnace problem processtech HVAC 5 11-13-2009 03:30 PM
carbon build up on nozzle zuni97 HVAC 8 01-20-2009 08:02 PM
confusion over thinsets for installing Ditra over heated flooring fhknox Flooring 12 01-19-2009 06:21 PM
