#1 |
Duel run cap with no info.
Hi DIY. New guy with a problem.
I have a nordyne A/C compressor and the fan is not working. The compressor does run. After pulling the fuse I can spin the fan easily with no binding. The duel run cap is very rusted and I can only identify C5C. The common terminal is melted and loose. The cover housing the the wires and board had a tag at one time but is now gone. The unit is about 15 or 16 years old and has no readable info. on it nor does the compressor itself. It is my understanding the volts can be different 370 or 440 but the microfadaders connot. How can I tell what duel run cap I have ? |
#2 |
Professional
nodyne's typically had a sticker in the electrical compartment with the model and serial of the unit....
IT IS WHAT IT IS To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
eyeball some of these might find it light sand paper over the stamped info might give it up http://www.bestbuyheatingandaircondi...ategory_Code=C
#4 |
Hi biggles. Thank you for the reply. I tried sanding with 800 but was ineffective.
Hi hvactech126. The electrical compartment had a sticker at one time. I can see the glue residue but the sticker is gone. I do have the fan motor info. and also found some compressor info. Fan motor = emerson model KA55HXSMP-23473, 1/4 hp volts= 208-230, HZ60, amp 1.7, ph1, rpm1075 compressor= copeland model CRG3-0250-PFV-270 serial# 93E30823A, LRA 75.8 If any of this is helpful I would greatly appeciate it. |
#5 |
Professional
you need a 35/5 mfd 440V capacitor
this should be your model number of your a/c : JS3BA-036KA
| The Following User Says Thank You to hvactech126 For This Useful Post: | ben's plumbing (05-07-2012) |
#6 |
Thank you very much for your help.
#7 |
Got a duel run cap today and installed it. A/C is working fine. Thank you hvactech126 and biggles for your input.
| Display Modes | |
| Sterling Tub Floor Texture and info?? | Trufans | Plumbing | 6 | 04-14-2012 12:58 PM |
| New DIYer here ... Need info on heat/AC unit | Snewman | HVAC | 9 | 01-21-2012 02:19 AM |
| need info on air compressor | donnydoon | HVAC | 4 | 02-01-2010 07:23 AM |
| GE Motor cross ref info | kcsimcoe | Electrical | 5 | 07-07-2009 12:36 PM |
| Conflicting Circuit Info!?? | BenBil | Electrical | 9 | 01-15-2007 09:26 AM |
