Ductwork Question - HVAC - DIY Chatroom Home Improvement Forum
Old 01-24-2009, 03:28 PM   #1
Rewards Points: 292
Ductwork question
What is the minimum distance from the end of a trunk, when adding a takeoff?
V
veesubotee is offline   Reply With Quote
Old 01-24-2009, 07:07 PM   #2
I've always been told 12-18" but, I'm not an installer.
sgthvac is offline   Reply With Quote
Old 01-24-2009, 07:38 PM   #3
tk03's Avatar
Rewards Points: 150
For proper static at the end of the duct it is 18"
tk03 is offline   Reply With Quote
Old 01-25-2009, 09:08 AM   #4
Rewards Points: 292
Wow, a little more than I had expected (hoped) for as there are some clearance problems.
My situation: My original ductwork is in need of some modification. Main trunk butt ends with a 5" & 6" takeoff on the butt. Prior to the end, there is a curved transition (smaller trunk) which runs perpendicular to the first section. At the butt end of that section is a 6" takeoff.
Both of the 6" runs are fed to the second floor and the airflow is anemic. So, I want to relocate those (3) runs off of the ends. I had planned to have both the 5" and 6" come off the underside close to the end (I have 10" of clearance until the transition).
18" would take me to the same center point as the transition, I mentioned. I could go farther back but would have to come off the bottom of the trunk (all other takeoffs are on top: problem?). The adjacent run could be fitted in.
Would there be a problem with 2 takeoffs being located at the same center point on different surfaces of the trunk? Probably not, as I just remembered that at the plenum, there is a 20" section of trunk which runs in the opposite direction. There are (3) 5" takeoffs on the underside about an inch from the end. There is also a 6" on the upper surface. It is only a few inches back from the end. The airflow from the 6" (upstairs) is very good; the 5's are dampered back.
The 3rd (last) takeoff would not be a problem.
I plan to use flexible metal duct to make gentle curves and eliminate some of the elbows while connecting to the existing ducts, and cap the abandoned ends.
Your comments and suggestions please.
V
Old 01-27-2009, 08:24 AM   #5
tk03's Avatar
Rewards Points: 150
I would avoid flexible metal duct for this change as there is far more Resistance to it than rigid duct. Even the insulated flex duct is far better than the metal flex duct. It still adds resistance so the flow would be reduced slightly. A complete system laid out with insulated flex must have some special attention paid to it.
framing around ductwork jcrampton Remodeling 12 08-01-2011 02:31 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 09:10 AM
New service Question Onytay Electrical 1 10-24-2007 05:47 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 10:17 PM
