Ductwork In Bathroom - HVAC - DIY Chatroom Home Improvement Forum
Old 05-28-2009, 06:40 PM   #1
Ductwork in bathroom
I'm in the process of remodeling our small half bath due to a rotten subfloor. When I pulled the existing vanity out, I noticed a false bottom with a register vent screwed to the kickplate. The 5 inch round ductwork stops flush with my subfloor. I was going to just install a boot. My floor joists are 16 in. on center, and there is one right next to the round duct work. There are also two joists sistered together on the other side of the duct, leaving me only 8 inches between the joists. I can't reroute the ducts because my furnace is in the way, and I don't want to use flexible duct work because then if I ever finish my basement it will cause problems. I also don't want to put the vent in the wall because I'm planning on using travertine on the walls and don't want to cause an eyesore. Does anyone have any suggestions/fixes?
craigsery is offline   Reply With Quote
Old 05-29-2009, 08:54 AM   #2
30 year tech
hvac122's Avatar
Is vanity not going back in the same spot? If it is you can use the toekick over again.
hvac122 is offline   Reply With Quote
Old 05-29-2009, 03:10 PM   #3
No, I'm putting a pedestal sink in to save on space
Old 05-29-2009, 03:23 PM   #4
You could cover it with a return air grill and add a butterfly damper in the duct work below to control air volume.
Jim Hart is offline   Reply With Quote
Old 05-29-2009, 03:27 PM   #5
Newbie Bill
Rewards Points: 522
Where is the pedestal going to sit in relation to the vent?
I am curious to see the solutions the pros come up with.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is online now   Reply With Quote
Old 05-29-2009, 03:56 PM   #6
Only other solution is to cut in a wall heat.
I'm trying to think how best to describe doing it but am experiencing a Senoir Moment right now.
Not a good idea nor is it code to just leave it in the floor. You get water (and need i mention what else could go in there?) in the ducts you'll be sorry.
hvaclover is offline   Reply With Quote
Basement bathroom rough in efrobert Plumbing 2 06-23-2011 04:54 PM
Plumbing Help for New Basement Bathroom morphers82 Plumbing 2 03-14-2009 12:17 AM
Steps for Bathroom Remodel? SeattleHome Building & Construction 7 10-09-2008 11:04 AM
