Ducts In Attic Or Crawlspace? - HVAC - DIY Chatroom Home Improvement Forum
Old 03-19-2009, 08:58 AM   #1
Ducts in attic or crawlspace?
I'm installing a new system and after learning way more than I expected to have to learn, I really only have one question left (i hope).
I have to put the air handler in the attic, so my question is; given that there are 2 truths, duct runs should be kept as short as possible, and floor registers are the best for heating, Should I use short runs and ceiling registers, or should I take trunks down to the crawl and run branch lines in the crawl over to the outside walls so I can have floor registers?
Thanks for any advice.
Mr Jones is offline   Reply With Quote
Old 03-19-2009, 09:21 AM   #2
An old Tradesmen
Rewards Points: 6,900
Select supply registers that throw the air down.
May want to have your return ran to the crawl to have a low return.
Old 03-19-2009, 02:05 PM   #3
Attic job
I would run the duct right down the middle of the attic with diffusers one way blow to the exterior walls and the return in the center hallway with the thermostat on the wall below the return air grill. Good Luck watch out for those sharp roofing nails.
SULTINI is offline   Reply With Quote
Old 03-19-2009, 07:59 PM   #4
Thanks you guys. I figured ceiling registers would be the proper thing to do.
Old 03-20-2009, 08:03 AM   #5
Attic job
Good Luck MR Jones, stay cool
Attic Smell from A/C - I'm at wit's end! cidsamuth HVAC 19 08-23-2016 05:36 AM
Raccoons in the attic electricpete Pest Control 17 05-12-2011 04:02 AM
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 12:42 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
crawlspace exposed to outside and damp djbauda Building & Construction 5 07-30-2007 07:49 AM
