I am in the middle of a kitchen remodel and I am wondering if I should add a vent for my OTR microwave. I live in a 2 story + basement colonial where the range is against an interior wall w/ about ~4ft from the distance to the exterior wall. I removed a soffit and I will be replacing it with another one that is smaller and matches the wood from the cabinets. There are two copper water supply lines ~2" above the cabinet over the microwave. Also there is a 3" waste pipe above the cabinets that is on outside wall that would prevent me from also having a clear shot. I am trying to figure out if a ductless vent is the way to go or not. None of my neighbors have a ducted vent. Also I am worried about codes and other problems that might occur from having a vent. I do live in upstate NY, so it can get pretty cold in the winter. We don't do a lot of cooking to turn on the vent, though I am wondering if the new kitchen would make us cook more often.
IMHO a range hood that doesn't vent outdoors is a complete waste of time. The ductless ones are useless. I want as much of the cooking odors to be exhausted from my home. I don't want to smell my evening dinner all night long.
I have had both systems. In my last three newly built homes, I insisted that the range hoods vent outside.
I guess I do get a little nervous when it comes to putting a hole in the side of my house. I wonder if there would be any grease on the siding and who would you call about having this installed? I am doing everything for my kitchen myself, except drywall seams and granite install. I guess I am running out of steam for wanting to learn new things.
I haven't read the whole thread, but the answer is you want to vent a microwave or simple range hood to the exterior if at all possible. Otherwise, the only use it will have is the light.
You can add carbon filters to a hood to remove odours, but venting is absolutely necessary if you want to remove heat, moisture, or exhaust from a gas stove.
For proper airflow, the pipe has to be sized correctly. Follow the manufacturer's instructions - I think most hoods need 6" hard pipe for optimal performance.
4" or flex will cripple anything which moves more than 100 cfm or so.
Related Threads
DIY Home Improvement Forum
3.1M posts
320.1K members
Since 2003
