Ductless Venting - HVAC - DIY Chatroom Home Improvement Forum
Old 03-14-2008, 10:48 PM   #1
ductless venting
i have a 200 year old stone house. there is no vent in the bathroom.
can i use a ductless vent ? if so what kind ? the walls are over 2 feet of stone. there is no easy way to put a vent in this bathroom
the bathroom is on the 2nd floor the third floor is a loft bedroom so i can't go up. does anyone have any ideas?
renee18103 is offline   Reply With Quote
Old 03-17-2008, 09:36 AM   #2
30 year tech
hvac122's Avatar
Code here requires all fans to be vented to the outside. Otherwise you will have humidity problems. Sometimes it is just no fun to go through those walls.
hvac122 is offline   Reply With Quote
Old 03-18-2008, 05:48 AM   #3
coolmen's Avatar
coredrill thru that sucker or call a pro
coolmen is offline   Reply With Quote
Old 06-05-2008, 09:48 PM   #4
bet it is chilly
ro9beam2002 is offline   Reply With Quote
Old 06-06-2008, 06:06 AM   #5
Unless you want to cut out wall and ceilings so you can get it to the roof. You will have to core a hole thru the wall. It'll be cheaper, easier and get the job done faster. Coring holes can be messy though and some hole coring company won't clean up or remove cut's without extra charge
Get some bids from a few pro's.
Chimichanga31 is offline   Reply With Quote
Furnace venting questions Mastiff HVAC 9 12-05-2012 06:51 PM
Ductless split system - advice mikeyd HVAC 9 06-26-2007 06:23 AM
Venting TonyD Plumbing 11 01-18-2007 07:31 PM
Crawl space venting... MLO Building & Construction 2 09-23-2006 04:18 PM
