Ductless System - Heat/Cool 2 Rooms With 1 Indoor Unit? - HVAC - DIY Chatroom Home Improvement Forum
Old 03-13-2013, 06:15 PM   #1
Ductless System - Heat/Cool 2 rooms with 1 indoor unit?
I have a Daikin 3-Port Ductless system installed by a local contractor in my basement. Currently I have two of the three ports used on two rooms in said basement. I have recently completed an addition of about 450 square feet on to the back of the basement and am having a third indoor unit installed next week by the same contractor.
This new expansion is divided in to two rooms - one will be used for a workshop approximately 10-12 hours per day (my wife and I run a small service business out of our home) and the other room will be used for shelved storage of moderately delicate items. These two rooms will be separated by a framed and insulated wall with a door.
Of course I am having the new third indoor unit installed in the workshop that we will be spending most of our time in. I would like to at least partially moderate the climate in the storage room as well by "sharing" some of the air in the workshop. Is there any way to accomplish this by installing a couple of vents in the separating wall or perhaps even a small fan or two to blow air from the workshop in to the storage area (or vice-versa)? I don't need the storage room to be necessarily "comfortable", just keep the temperature above 60 in the winter and below 90 in the summer (we are in the Atlanta area). The side benefit would also be to keep the humidity down a little.
I understand that without either a direct 4th system or a supply/return setup that I won't be able to have any kind of strict control over the climate - I just need a solution to "take the edge off" so to speak.
Thanks for any help you can offer.
KG4ONJ is offline   Reply With Quote
Old 03-13-2013, 06:29 PM   #2
An old Tradesmen
Rewards Points: 6,464
Put a vent high on the wall and low on the wall.
Old 03-13-2013, 06:34 PM   #3
Thanks for the reply! Any suggestion for what size vents or what style?
What will this do for me in the end?
Old 03-13-2013, 06:51 PM   #4
An old Tradesmen
14X8 Hart&Cooley A650.
Ho much they will do will depend on how packed the storage room is. They should get you about what you want, except for humidity control. That is dependent the workshop humidity also.
The A650 is a fairly free flowing register. So make sure you don't put a desk in front of it, or someone could get old feet.
Old 03-13-2013, 09:28 PM   #5
Excellent! Should I create a duct through the wall between each grille pair? Is there any kind of "pre-fab" item for this to go through a 2x4 wall?
Old 03-13-2013, 09:48 PM   #6
An old Tradesmen
No need for a duct. No prefab that I know of.
Old 08-27-2013, 10:06 PM   #7
Rewards Points: 28
Ductless mini-splits are great for a lot of applications. The challenge can be getting air into a small side room. Take a look at a product called AirShare by Tjernlund. It's a retrofit fan that uses the cavity between two studs as a duct. The fan is installed low on one side to draw air in and a vent is installed high on the other side to distribute the air. Install right below an electrical outlet and hardwire it for power. They work well and are really quiet.
AtticFoil.com is offline   Reply With Quote
Old 08-28-2013, 07:19 AM   #8
AKA HVACTECHFW
Rewards Points: 1,208
I agree you should look at the aireshare.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Buying a used AC system. forJAT HVAC 3 12-17-2011 10:52 AM
Need help with finishing touches on radiant heat system gbwillner HVAC 6 12-03-2011 12:16 PM
hydronic radiant floor system with potable water radiators thejaybird HVAC 2 11-09-2011 06:10 PM
Ductless split system - advice mikeyd HVAC 9 06-26-2007 06:23 AM
Size A/C system properly 70stang HVAC 1 03-26-2006 08:22 PM
