Ductless Minisplit Question - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-15-2013, 08:10 AM   #16
Hvac Pro
yuri's Avatar
Rewards Points: 380
overcooled IMO is not possible as it will cycle on the thermostat anyway. some extra capacity is a good idea and a high quality minisplit is very quiet anyway. unlike dehumidifying a whole house just doing one room I doubt humidity removal is his major concern. you can install it yourself but unless you have very good mech skills it is not as easy as it seems or people say. the freon level needs to be checked after install and if you don't have ALL the proper gauges and install tools it would be better to get a \pro to do it. The quietest best unit IMO is a Fujitsu but they are expensive. Very well built and quiet etc. Generally the only DIY units are the cheaper clone brands so if you want the quietest that may your best bet. The reason I say quietest is sound is a major issue in a theater room so you may want to research the higher quality/priced units. Mitsubishi is also very good.
http://www.mitsubishicomfort.com/en/...oduct-showcase
http://www.fujitsugeneral.com/products.htm
Old 03-15-2013, 11:06 AM   #17
747
registered
747's Avatar
Rewards Points: 534
Simplest installation would be on an interior exterior wall. I was also thinking 12,000 btu when reading your original post. Seeing how its a theater room. Yes they are sweet. Whisper quiet. Work off hand held remote control.
747 is offline   Reply With Quote
Old 03-16-2013, 03:04 PM   #18
Rewards Points: 150
Exclamation
So i've been wracking my brain trying to figure out how to best keep my air sealed theater room cycling fresh air and be able to somewhat control the temp of the room without getting way too expensive. I was going to build a deadvent for the return in the theater room and leave the supply from the furnace as is and see how it handles the equipment and people in the room. But then someone asked me if I have aother return for the basement, which I do not and that could be a problem as far as cycling air when the theater room is in use.
I took a couple pictures of the return trunks for my furnace and are these possible closed off vents that used to be, or could be made in to a return?
Ductless Minisplit question-100_3477.jpg   Ductless Minisplit question-100_3478.jpg
Mijotter is offline   Reply With Quote
Old 03-16-2013, 05:41 PM   #19
Rewards Points: 150
anyone?
Old 03-16-2013, 06:08 PM   #20
An old Tradesmen
Rewards Points: 8,142
A register could be cut into one of them.
Old 03-16-2013, 06:19 PM   #21
Rewards Points: 150
beenthere my HVAC super hero hehe. Good to hear I can put a vent in there. That's a big weight off my shoulders.
Old 03-16-2013, 07:37 PM   #22
Rewards Points: 150
what size hole/vent should it be?
Old 03-16-2013, 08:16 PM   #23
An old Tradesmen
Same size as the vent through the wall.
Tags
basement , cooling , duct , heating , mini split
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 01:48 PM
Plumbing for new shower kit question noviceshock Plumbing 6 03-02-2013 08:11 PM
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
Thermal Zone Ductless Minisplit wrldruler HVAC 3 02-23-2009 05:31 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
