Ductless Mini Splits - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-15-2013, 01:06 AM   #16
AKA HVACTECHFW
Rewards Points: 1,208
what kind of real world data do you want?
In January 2010, temperatures dropped to -10 degrees. When I checked my cabin interiors, every one held a temperature of 65 degrees, just where I had set them. My January per cabin heating cost was cut in half! Mitsubishi Electric’s performance exceeded my expectations.”
http://www.mehvaccasestudies.com/case_studies/view/71
I'm sorry, but you said you were intrigued, but when I gave you information you said you want real world data...... Sounds like you just don't believe anything. Good luck.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 01-15-2013, 01:13 AM   #17
Rewards Points: 156
In the case you just provided, the testimonial replaced an oil space heater. I'm more interested in a direct comparison between heating with natural gas vs a split system.
strategery is offline   Reply With Quote
Old 01-15-2013, 01:20 AM   #18
AKA HVACTECHFW
IF that is the case then you have to do the math to figure out the electric rates Vs. Natural gas cost of what ever type of NG system you would have. Call a dealer and have them give you the figures for YOUR area. Mini splits are great for add-on rooms, or the like. Personally, I prefer my ducted central HP with NG aux heat for my home. I use the mini-split for the 3 season room to make it a 4 season room. At the seer and HSPF ratings these are being produced to achieve these are a viable option in most all climates.
IT IS WHAT IT IS
Why does a ductless mini split need to be a minimum of 5' off the floor? jayp HVAC 5 09-15-2011 11:12 AM
Oversizing Mini Splits kmachn HVAC 6 07-28-2011 04:29 AM
DIY mini splits benjamincall HVAC 1 01-23-2009 08:44 AM
DIY Mini splits - Reality Check - What does it take? Leah Frances HVAC 8 12-17-2008 12:04 PM
Installing a mini split ductless system agenkin HVAC 1 06-14-2008 09:33 PM
