Ductless Mini-split Installation. - HVAC - DIY Chatroom Home Improvement Forum
Old 08-06-2009, 07:46 AM   #1
Rewards Points: 292
Ductless mini-split installation.
Just curious: are the outdoor units ever mounted lying down on a sloped roof, or must they be installed against a vertical wall?
V
veesubotee is offline   Reply With Quote
Old 08-06-2009, 02:50 PM   #2
There has to be air flow through the unit. So no, you can't lay it on a roof and no it can't be mounted against a wall. The installation instructions will provide the specifics.
SKIP4661 is offline   Reply With Quote
Old 08-06-2009, 03:15 PM   #3
Rewards Points: 292
Do you mean that there has to be an air space between the unit and the mounting surface?
V
Mini Split for heating in cold climate landev HVAC 9 01-29-2012 11:18 AM
Mini split Slimbad HVAC 1 06-28-2009 08:21 AM
Installing a mini split ductless system agenkin HVAC 1 06-14-2008 10:33 PM
Ductless split system - advice mikeyd HVAC 9 06-26-2007 06:23 AM
