Ductless Mini-split AC/heat Pump, Determining Size - HVAC - DIY Chatroom Home Improvement Forum
Old 10-12-2011, 03:36 PM   #1
Rewards Points: 197
Ductless Mini-split AC/heat pump, determining size
I'm considering putting one of these mini-split ductless heat pump/ac units in the house I'm building.
I need to know about what size I should be looking into.
The location is western, central Arkansas.
It can get above 100 for several weeks in the summer
and down near 0 for several weeks in the winter.
The house is 24' x48' (just under 1200sq.ft.).
It will have R28 in the floor, R23 in the walls and R40+ in the ceiling. It has 11 double pane, lo E windows.
The layout is basically an open LR,Kit,DR, 1 bath, 2 bedrooms, utility room and pantry.
I'm thinking of just a 1 zone unit installed in the LR or DR.
What would be the approximate size in BTU's that I would need for cooling and also for heating ?
And should I consider a model that has an auxiliary built in resistance heating strip ?
I've heard that the Mitsubishi Mr. Slim units are very good.
Anyone have any experience with them ?
Best place to buy, etc. ?
Thanks,
Arky
Arky217 is offline   Reply With Quote
Old 10-12-2011, 04:19 PM   #2
Rewards Points: 1,528
Suggest moving this to the HVAC forum.
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
Gary in WA (10-13-2011)
Mini Split for heating in cold climate landev HVAC 9 01-29-2012 11:18 AM
Intermittent submersible pump fault esquilax Electrical 5 09-30-2011 04:56 AM
Need help determining the size of an upstairs HVAC unit BigE516 HVAC 11 03-17-2009 04:25 PM
Installing a mini split ductless system agenkin HVAC 1 06-14-2008 10:33 PM
Ductless split system - advice mikeyd HVAC 9 06-26-2007 06:23 AM
