Ductless Havc - HVAC - DIY Chatroom Home Improvement Forum
Old 02-18-2013, 03:22 PM   #1
ductless havc
I want to install a ductless havc unit myself. Can you purchase a unit that is precharged with, and if so from which company?
johnmac is offline   Reply With Quote
Old 02-18-2013, 04:49 PM   #2
747
registered
747's Avatar
Rewards Points: 534
if your talking Mitsubishi heat and cool unit. They are precharged.
747 is offline   Reply With Quote
Old 02-18-2013, 05:33 PM   #3
Rewards Points: 12
No warranty unless you are a certified HVAC person.
ratflinger is offline   Reply With Quote
Old 02-18-2013, 05:49 PM   #4
Not true, depending on brand, many HVAC systems are warrantied regardless of who installed them. To the OP, most of the ones I've seen are already precharged.
GarrettFiveZero is offline   Reply With Quote
Old 02-18-2013, 06:44 PM   #5
An old Tradesmen
Rewards Points: 7,370
Mini splits come precharged for X length of line set.
Old 02-18-2013, 06:52 PM   #6
Rewards Points: 156
They are pre-charged, but you will need to use a vacuum pump to vacuum the lines of air once everything is connected up. This also allows you to check for leaks, as the vacuum should hold for over an hour once it's pulled down (If you see gauge moving back up, it's time to go back and check your connections) Once the lines are vacuumed down and all air/moisture is removed, you can then open the valves on the outdoor unit and let the refrigerant into the lines and the indoor unit...the system will then be ready for use.
If you want to install the system yourself, you will need to borrow or rent a vacuum pump. You should not need to add any charge to the system. Most mini-splits have enough charge for a 25 foot lineset. A longer lineset will require more refrigerant than what's contained in the outdoor unit's compressor.
av-geek is offline   Reply With Quote
Old 02-18-2013, 10:43 PM   #7
Rewards Points: 12
I should have qualified that more - I believe Mitsubishi and most of the others require a HVAC professional to make the final connections, perform any testing & start the unit.
Ductless Mini Splits JackOfAllTrades HVAC 17 01-15-2013 01:20 AM
Ductless AC btus billybarty HVAC 5 09-14-2012 03:10 PM
Ductless Air Conditioner DIY? wb8imy HVAC 3 04-15-2012 09:00 PM
Ductless Mini-Split Opinions BFR HVAC 4 12-13-2010 04:15 PM
Floor Vents for A/C? + Ductless for upstairs? dwbc153 HVAC 0 08-02-2009 12:14 PM
