Ducting Question - HVAC - DIY Chatroom Home Improvement Forum
Old 08-23-2009, 08:30 AM   #1
Rewards Points: 292
Ducting question
One particular run (2nd floor) is long and tortuous.
Its takeoff is located close to the basement furnace. There is a section of 6" duct (accessible) which runs about 20 feet, then elbows up into the structure (not accessible).
Would increasing the size of the 20 foot section change the dynamic of the airflow (CFM/velocity) into that room?
V
veesubotee is offline   Reply With Quote
Old 08-23-2009, 10:16 AM   #2
http://www.engineeringtoolbox.com/du...oss-d_444.html
gives you duct friction but you also need the 'fan curve' for your HVAC system to solve for the end result CFM and FPM.
BTW, a low-tech way of measuring CFM is to tape a huge garbage bag over the register and time how long it takes to fill it.
For approximate velocity in feet/minute, divide the CFM by the duct area [0.2 ft² for a 6" round duct, so 100 CFM would equal 500 FPM].
You could also try a variable speed duct booster fan, but it also boosts the noise level so put the fan at the takeoff end. Comfort vs. fan noise is up to each person so with variable speed you can select your own optimum point.
Old 08-23-2009, 06:13 PM   #3
An old Tradesmen
Rewards Points: 7,816
Yes it would. How much depends.
You may also need to increasethe amount of return you have.
Old 08-24-2009, 05:20 AM   #4
Rewards Points: 292
You may also need to increase the amount of return you have.
Been, would this work with an 'increaser' you mentioned in the 'other' forum?
V
Old 08-24-2009, 05:25 AM   #5
An old Tradesmen
Best if you use a take off the size the new duct is, from the main duct/plenum, and then use a reducer at the end that goes into the unaccessable area.
Old 08-24-2009, 05:52 AM   #6
Rewards Points: 292
I thought that your answer would be something along that (above) line LOL.
V
Bathroom ventilation question - tight workspace! Hawkeye HVAC 2 08-18-2009 03:31 PM
Installing Ducting for New Home Addition marshstate HVAC 12 07-19-2009 09:23 PM
Bathroom Exhaust Ducting Question ande3171 General DIY Discussions 2 04-20-2009 05:59 AM
Ducting question? thunderhead HVAC 4 03-25-2009 04:52 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 10:17 PM
