Old 03-24-2009, 10:34 PM   #1
Ducting question?
Put a new furnace in my garage. It is a upflow Lennox model. I was wondering if it is worth the effort to run ducting from the plenum down to the floor and then coming out at a 90 angle or just run a couple elbows out the top. It would be nice to have heat at floor level but not sure if it would just rise so fast it wouldnt do much good.
thunderhead is offline   Reply With Quote
Old 03-24-2009, 11:20 PM   #2
HVAC / Plumbing
Ducting question?
If the furnace is gas & it is sitting on the garage floor. make sure the return air & furnace itself isn't able to draw in any flammable vapors.. ells etc on the top should be fine for heating a open garage area
kenmac is offline   Reply With Quote
Old 03-24-2009, 11:49 PM   #3
hvaclover's Avatar
Ducting question?
Furnace in garage must be elevated at least 18" off the floor.
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 03-25-2009, 12:18 AM   #4
HVAC / Plumbing
Ducting question?
John , kinda funny how it is in different areas.. They don't make you install a furnace 18'' off the floor here in any city / county limits.. Some cities / counties make you install the new style flame guard water heaters 18'' & some don't...Code states that if it'e a flame guard style water it doesn't have to be on a stand......Inspectors they are they love to play god when you are in their area
Old 03-25-2009, 05:52 AM   #5
An old Tradesmen
Ducting question?
For what ever dumb reason.
Some inspectors do consider a water heater with flame guard as a source of ignition.
All sources of ignition must be min 18" above floor in a garage.
A blower motor is a source of ignition.
Not enforced in all areas.
But that doesn't make it right not to raise it.
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
hrv question indep HVAC 3 07-17-2008 11:39 PM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 10:10 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 11:17 PM
Water in Furnace Ducting sdoca HVAC 3 09-14-2007 07:54 AM
