Ducting Problem For An HRV - HVAC - DIY Chatroom Home Improvement Forum
Old 03-04-2010, 11:32 PM   #1
Ducting problem for an HRV
Ok guys, Here's the problem.
I am retrofitting an old house with an HRV and cannot decide the best way to run the stale-air-ehaust.
Here's what I'm planning to do:
HRV located in basement of bungalow, run one 12"x3" wall stack up to the attic, and then, using a 12x3 to 6"round stack boot, spider 6" insulated ducting to the bathroom, kitchen, living room, and main bedroom using ceiling diffusers.
I also want to run a few diffusers to the basment.
I will be running the fresh air return through the existing furnace ducts.
Does this sound acceptable?
Will I achieve an adequate draw to the HRV using this method?
Please help me out with any suggestions or advice,
wiers is offline   Reply With Quote
Tags
ducting , hrv
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 07:42 PM
flame sensor problem junkcollector HVAC 1 12-09-2009 09:19 AM
Confused ducting in 1 story bungalow... HandyBro HVAC 1 07-16-2008 09:11 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
