Ducting Issue?? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-28-2010, 02:10 PM   #1
Ducting Issue??
Hey guys & gals,
I realized recently that our vents downstairs were not blowing with the pressure that they use to. I opened up the doors where our heating unit is and found this (see pics below). Initially this seemed like an easy fix until I looked further into it. It is a 12" coil duct connected to a 12" 90 degree bend coming out of the unit. It looks like the original installer smashed the 90 to make the radius. this ultimately led to the 90 degree bend breaking into 2 pieces and the coil duct eventually split, since there was no support.
My issue is that the largest part to actually access the duct and try to remove & repair is only 7". I suppose I could use some shears to cut up the existing 90 degree elbow, but how would I get a new one back in? The wall to the left of the unit is easily accessible, but I'd really like to try and fix this without tearing into the drywall.
Any advice would definitely be appreciated!
Thanks!
Ducting Issue??-img_5933.jpg   Ducting Issue??-img_5934.jpg   Ducting Issue??-img_5935.jpg   Ducting Issue??-img_5936.jpg   Ducting Issue??-img_5937.jpg
ddurant is offline   Reply With Quote
Old 11-28-2010, 04:28 PM   #2
An old Tradesmen
Rewards Points: 8,236
There is no easy fix for that.
Old 11-28-2010, 04:38 PM   #3
Understood. What would be your recommendation? Remove the drywall on the left for full access? Or is there a less intrusive fix (not necessarily easier).
Thanks.
Old 11-28-2010, 04:47 PM   #4
An old Tradesmen
Afraid it looks like you have to cut out the drywall.
Interlock Paver Issue cbadrik Landscaping & Lawn Care 2 07-27-2009 07:29 PM
Installing Ducting for New Home Addition marshstate HVAC 12 07-19-2009 09:23 PM
HELP - with my breaker box. Interesting issue. LordX Electrical 75 02-23-2009 03:14 PM
Cable issue or wiring issue? Duchey Electrical 57 12-15-2008 01:34 PM
Confused ducting in 1 story bungalow... HandyBro HVAC 1 07-16-2008 08:11 PM
