Ducting Hrv Into 2x4 Wall Framing - HVAC - DIY Chatroom Home Improvement Forum
Old 03-31-2008, 04:44 PM   #1
Ducting hrv into 2x4 wall framing
Hi,
For HRV only; how does duct are put in a 2x4 frame ? can I use a 4" flex with a 90 degree elbo to connect to a 4" diffuser on the bedroom wall ? Or I must build a box inside the closet and if so how big ?
zappaesque is offline   Reply With Quote
Old 03-31-2008, 05:57 PM   #2
hvac/refrigeration
Get some 3 1/4" X 10 wall stack, a stackhead and 4" stackboot.
metal-maniac is offline   Reply With Quote
Old 04-01-2008, 03:14 PM   #3
thank you. it's becoming clearer
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 04:44 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Framing an angled wall TheBrownsFan Building & Construction 8 01-14-2007 10:22 AM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
