#1 |
Ducting ceiling fan into dryer vent?
I I'm a new home owner and re doing my bathroom. It has no ceiling fan and I need one to install the shower? My shower is located right next to a window(window is actually on shower), so that could r an alternative idea. I was wondering if I could install the ceiling fan and just duct it down into my dryer duct and install a t with one way flaps on each side.
Would this meet code? How important would it be to meet code? Do I even need the fan, I rarely used at houses I rented anyways |
#2 |
Bchill
they all have to be vented separately, codes are set out for safety
#3 |
No, No, No. Not going to meet any code on this planet.
Dryer needs it's own vent, to meet code it also should only have a metal flex line not the cheap plastic ones, soild metal pipe if it's behind a wall or through the attic. And yes a bathroom vent is very important and also needs to be vented outside not just into the crawl space or attic. |
#4 |
Hmm... many, if not most codes don't require a fan unless there is no window.
#5 |
You could use the same vent as dryer,but your clothes might smell funny.
#6 |
as already said..needs to be vented by itself....no if ands or butts about it...
#7 |
Bchill
Ducting ceiling fan into dryer vent? Im pretty sure that you can't vent a dryer and bathroom out the same vent.
#8 | |
Ducting ceiling fan into dryer vent?Quote:
| Display Modes | |
| Dryer vent leaking | imhotep | Roofing/Siding | 7 | 12-28-2011 04:54 PM |
| Dryer vent problem | carguy4sp | General Discussion | 7 | 11-29-2010 09:26 AM |
| attach bathroom fan vent to dryer vent | hohadcr | HVAC | 9 | 03-08-2010 06:58 PM |
| Dryer vent backdraft damper | BlueCrystalMan | Building & Construction | 4 | 01-01-2010 03:26 PM |
| Dryer Vent Ducting | cocean | HVAC | 2 | 08-08-2009 02:20 PM |
