-   -   Ducting ceiling fan into dryer vent? (http://www.diychatroom.com/f17/ducting-ceiling-fan-into-dryer-vent-153054/)
hi2u 08-08-2012 09:34 AM
I I'm a new home owner and re doing my bathroom. It has no ceiling fan and I need one to install the shower? My shower is located right next to a window(window is actually on shower), so that could r an alternative idea. I was wondering if I could install the ceiling fan and just duct it down into my dryer duct and install a t with one way flaps on each side.
Would this meet code? How important would it be to meet code? Do I even need the fan, I rarely used at houses I rented anyways
Acomfort 08-08-2012 09:41 AM
they all have to be vented separately, codes are set out for safety:thumbsup:, I would follow them, and by not venting the bathroom you run the risk of mold buildup
joecaption 08-08-2012 09:44 AM
No, No, No. Not going to meet any code on this planet.
Dryer needs it's own vent, to meet code it also should only have a metal flex line not the cheap plastic ones, soild metal pipe if it's behind a wall or through the attic.
And yes a bathroom vent is very important and also needs to be vented outside not just into the crawl space or attic.
operagost 08-09-2012 03:28 PM
Hmm... many, if not most codes don't require a fan unless there is no window.
bobelectric 08-09-2012 05:06 PM
You could use the same vent as dryer,but your clothes might smell funny.
ben's plumbing 08-09-2012 06:32 PM
as already said..needs to be vented by itself....no if ands or butts about it...
Acomfort 08-09-2012 06:32 PM
:no:Im pretty sure that you can't vent a dryer and bathroom out the same vent.
and your right:yes:
