Is This Duct Wrap Asbestos - HVAC - DIY Chatroom Home Improvement Forum
Old 10-25-2012, 12:54 PM   #1
Is this duct wrap asbestos
Hello
I had a hvac company out earlier to inspect the furnace etc and I asked about adding a dampener onto a duct line that runs to my sons room. It is cranking it out at 1600 CFM and I want to reduce it for the size of the room. When they went into the attic they said we can do it because that duct has an asbestos wrap on it.
I did some research and it looks like that this is a fiberglass wrap and not asbestos but I wanted to see what everyone else thinks.
rubiks1 is offline   Reply With Quote
Old 10-25-2012, 03:23 PM   #2
Rewards Points: 70
Not sure that anyone can answer that by visual inspection. A test maybe in order. Just dot make it airborne! For now.
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
The Following User Says Thank You to digitalplumber For This Useful Post:
joecaption (10-25-2012)
Old 10-26-2012, 03:48 PM   #3
I called another hvac company and sent a pic to them and they said it was fiberglass insulation BUT what is under it is the question. In short they said leave it alone until they come out for the dampener install and they will determine then.
Old 10-26-2012, 04:19 PM   #4
Civil Engineer
Rewards Points: 4,790
The question of whether product X contains asbestos or not has been discussed ad nauseum on this forum, do a search for dozens of threads on this topic. The short answer is that there is NO WAY to determine if product X contains asbestos without a laboratory test. Presumably your furnace contractor intends to send a sample to a lab, since there is no possible way they can make a field determination.
Daniel Holzman is online now   Reply With Quote
The Following User Says Thank You to Daniel Holzman For This Useful Post:
carmon (10-26-2012)
Old 10-27-2012, 06:23 AM   #5
Agree with previous poster, there is no way to tell without testing.
You might get a fairly good idea if asbestos was used when the duct work was installed. i.e. do you know what year it was installed.
If in doubt don't mess with it. It only becomes dangerous if airbourne.
If you are worried, get a specialist asbestos removal company in.
Gissle is offline   Reply With Quote
Asbestos Duct Wrap Etrace0921 HVAC 17 08-25-2014 10:49 AM
Asbestos Duct Wrap jvc120er HVAC 16 02-19-2012 05:19 PM
Planning on New duct work..any feedback... kilosos2 HVAC 28 01-26-2011 09:21 AM
Asbestos on ducts and duct supply boots DanGauer HVAC 4 08-31-2010 07:09 AM
i need some helpful advice on duct wrap andrewmiles HVAC 1 04-19-2010 09:16 PM
