Duct Work Size - HVAC - DIY Chatroom Home Improvement Forum
Old 09-19-2008, 07:47 PM   #1
duct work size
I am trying to install a furnace in my home, The furnace is a gibson 95% 70,000 btu. I live in Tenn near the MS state line so winter is not bad coldest it gets in the dead of winter is about 20 degrees and warms above freezing durning day. My home is small 24ft wide by 58 ft long. The blower cfm size is 1450 cfm without filter. I am trying to figure out the trunk size for ducting and should it be all one size or should it start out large and be reduced . I am talking about the main duct that goes the length of house which is being installed in attic furnce in closet. Also how many air returns should I have and the size of them. Any help would be great. Thank you for you time Charlie
justmefixin is offline   Reply With Quote
Old 09-20-2008, 11:53 AM   #2
1610 CUB's Avatar
Rewards Points: 150
I would like see an insulated 8"X12" main duct going two ways. If it has to go one way only you will need to start out with a 9"X 25" or a 12"X18" something with 200sq/in ID. Then reduce after 20' or so. This duct needs insulated either inside or rapped outside. Adjust the size up for inside insulation.
You don't say how many rooms, but you will need 4- 8" round R/A ducts and 8- 6" S/A ducts, all need to be insulated.
8" run = 50 sq/in and a 6" run = 30 sq/in.
I hope it helps
1610 CUB is offline   Reply With Quote
Old 09-20-2008, 07:59 PM   #3
I hope it helps
Thanks Charlie
Tags
help with ducting
DIY Air Duct Cleaning... How to? singforsupper HVAC 5 10-09-2008 01:06 PM
Duct Work Question xlr8tn HVAC 1 01-19-2008 10:02 AM
Am I being overcharged for general construction work? baloney12 Building & Construction 2 07-11-2007 07:09 PM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 11:56 AM
Duct sizing question Rob HVAC 1 06-04-2005 01:42 PM
