Duct Work - HVAC - DIY Chatroom Home Improvement Forum
Old 03-10-2011, 12:43 PM   #1
Duct work
Aim putting in a 3 ton heat pump my main trunk is 12 x8 x 20 a self contained unit I have four 6 inch rounds running off for the living room 16x32
Now I need to know what size round flex pipe should I use to to duct it up stairs I have four rooms 12x15 gaining to use one 6 inch round in each room over each window would a 10 inch round work fine if not can some one give me the right lay out tks much
tootsie007 is offline   Reply With Quote
Old 03-10-2011, 01:47 PM   #2
Generally, air flow needed is .8 - .9 cfm per sq. ft., assuming 8' ceilings and avg. heat load.
Metal round duct: 6" = 85 cfm. 10" = 325 cfm
Poppyloppy is offline   Reply With Quote
Old 03-11-2011, 05:30 AM   #3
An old Tradesmen
Rewards Points: 7,318
Your 12X8 main trunk is about the right size for a 1 ton unit. 28X8 or 22X10 would be more appropriate for the main trunk.
Planning on New duct work..any feedback... kilosos2 HVAC 28 01-26-2011 09:21 AM
Whole house fan using old soffit duct work zacman General DIY Discussions 11 06-19-2010 11:57 AM
Heat Duct work coachrenzo Building & Construction 0 06-17-2010 07:46 AM
Toughest duct work I can get? napper HVAC 7 07-30-2008 10:52 AM
Modifying existing duct work Thurgee HVAC 3 04-05-2007 09:35 AM
