Old 11-17-2012, 12:42 PM   #1
duct work
what would be the best way to insulate this exposed duct work?
redman88 is online now   Reply With Quote
Old 11-17-2012, 07:30 PM   #2
duct work
put insulation on it.. then a weather proof wrap..... costs about $110.00 per foot around here...
carmon is offline   Reply With Quote
Old 11-17-2012, 07:45 PM   #3
duct work
i would also put some type of roof over it. to shield it from the sun.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 11-17-2012, 09:19 PM   #4
duct work
Isnt it already insulated on the inside?
southernkilowat is offline   Reply With Quote
Old 11-17-2012, 11:44 PM   #5
duct work
insulating the ducts interior with fiberglass sucks imho
Chimmy is offline   Reply With Quote
The Following User Says Thank You to Chimmy For This Useful Post:
switaina (11-18-2012)
Old 11-18-2012, 01:26 AM   #6
duct work
It is insulated on the inside. Some day I will reroof the house and put all this in the attic
Old 11-18-2012, 05:41 AM   #7
An old Tradesmen
duct work
Your outdoor humidity may be low enough you don't need to worry about the sheet metal sweating if you also wrap it. But before you do. Put a temp sensor on the supply and then cover that area with a piece of insulation 1'X1' of the same value you intend to use. Run the A/C and see how cool it gets. If it gets cooler then the outside dew point, you could end up rusting out your sheet metal before you plan to re-roof.
Advice for installing duct work for finishing basement captainj98 HVAC 1 05-11-2011 08:01 PM
Planning on New duct work..any feedback... kilosos2 HVAC 28 01-26-2011 10:21 AM
HVAC duct work radiates 60Hz Mike in Arkansas Electrical 3 01-01-2010 08:29 PM
Toughest duct work I can get? napper HVAC 7 07-30-2008 11:52 AM
Modifying existing duct work Thurgee HVAC 3 04-05-2007 10:35 AM
