Old 03-01-2009, 07:12 PM   #1
duct trunk diy site
I have a two story home built in 1945. The house is 24'x24'. The current trunk line in the basement starts off very large and then gets progressively smaller on the supply and return lines.
I'm planning to have the furnace replaced with a 92% or higher efficient furnace.
I would like to make the trunk smaller so that I can get more headroom for a basement washroom. I figure this would be a good DIY project. Is there a good site that I can learn about duct design?
unixb0y is offline   Reply With Quote
Old 03-01-2009, 08:41 PM   #2
It was a dark and stormy
Yoyizit's Avatar
duct trunk diy site
http://ateam.lbl.gov/Design-Guide/DG...worksizing.htm
The requirements of your high eff. furnace might conflict with reducing the duct size.
Old 03-01-2009, 09:26 PM   #3
tk03's Avatar
duct trunk diy site
The first thing you need to know is the furnace size. If sized properly not off the old one there may be a chance of making the duct smaller. If adding A/C you may not be able to reduce. Size equipment first.
See more info on furnace sizing
www.comfort-calc.net/home-page.html
tk03 is offline   Reply With Quote
Old 03-01-2009, 09:34 PM   #4
wannabe
duct trunk diy site
Your duct size will have to be matched to the CFM'S of the blower @ ???? static pressure.If you decrease the duct size. You may get some air noise in the house & may not get enough air flow across the A/C coil or heat exchanger
kenmac is offline   Reply With Quote
Old 03-02-2009, 06:37 AM   #5
An old Tradesmen
duct trunk diy site
If your old furnace was an 80,000 BTU output, it probably moved about 925CFM.
A new 60,000 BTU output furnace will need to move the same 925 CFM to stay within its safe temp rise ratings.
More On This Topic
Think about the access you need to plumbing and heating when remodeling your basement. Learn about furnaces and other services in finishing a basement from a professional remodeler in this free home improvement video. Read More »
DIY wedding decorations can be as simple as a basket of fruit or as complicated as an ornate floral bouquet. Experiment using a variety of materials and edible accents to create custom wedding decorations with information from an experienced event... Read More »
About DIY Plumbing
About DIY Plumbing by Shawn Kenny
Before tackling plumbing problems at home, make sure to get the proper tools and mindset for the job at hand. Avoid making huge mistakes when fixing plumbing issues without professional assistance with help from a plumber and HVAC tech in this free video... Read More »
DIY Halloween Decorations
DIY Halloween Decorations by expertvillage
Want to save money on Halloween decorations? Learn do it yourself ideas for indoor Halloween decorations in this do it yourself Halloween decorations video. Read More »
DIY Soundproofing
DIY Soundproofing by Arthur Noxon
In DIY soundproofing, sheet rock needs to cover any windows. Soundproof a room personally with tips from an acoustics specialist in this free video on soundproofing. Read More »
Return duct "boot or no boot" ads67 HVAC 16 01-10-2009 10:38 AM
Furnace install in attic - Duct configuration hartkem HVAC 6 11-08-2008 06:46 PM
Flex Duct Advice ssporty21228 HVAC 4 07-23-2008 09:28 PM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 03:33 PM
1000-1400cfm...duct sizing Swordfish215 HVAC 1 01-15-2007 04:22 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
