Duct Trunk Alternatives
I suppose it's possible I'm crazy, but is there a good reason not to use plastic for main trunks on my forced air furnace? My initial concerns were off gassing, mold, and static electrity. From what I'm reading, HDPE doesn't have the off gassing problems of polypropylene, doesn't have mildew problems (plus, I don't have air conditioning anyway), and I'm totally unsure of whether static electricity would be a problem.
I've seen the foil-faced cardboard panels for return air and was thinking the same type of thing should work for hot air. Initially I thought corrugated HDPE would be best as it would insulate as well, but I'm not sure if that would be worth the price compared to regular HDPE panels. EIther should install easily and may be a lot cheaper than metal. So, any thoughts? |
Insulated flexable ductwork is made for cooling and heating.
Plastic is a fire hazard. |
How is plastic a fire hazard? It melts at 162, far above the 110 coming out of the furnace. How is the flexible not the same hazard? |
http://plasticsupply.net/Ducting.html
http://www.harrisonplastic.com/ductwork.html Check those sites out. |
That's the first I've ever heard of plastic duct.
I never heard of it either and I have done work in several labs.
I'll bet that stuff costs an arm and a leg. Sounds like overkill for a residential home. I would run regular galvanized main trunk line and have flex takeoffs to the diffusers. Then insulate the main. OH ! That's for an attic installation, if it's ground floor or basement feeding up I would use galvanized main trunk with regular galvanized pipe to the diffusers. |
| All times are GMT -4. The time now is 08:49 PM. |
