Duct Sizing And Replacement - HVAC - DIY Chatroom Home Improvement Forum
Old 07-26-2010, 07:48 PM   #1
Duct Sizing and Replacement
I am thinking of running new duct work through my basement, one of the big reasons is because A) it is 46 years old B) I believe it sized wrong and C) I don't like the way it was run.
How do you figure the sizing of the main duct that all the runs link off of? Currently I believe the main duct is much to large, and if so it will give me more head room for my finished basement project. Is there a calculator for the amount of air moved?
DAdams982 is offline   Reply With Quote
Old 07-26-2010, 08:40 PM   #2
What's the size of your AC? What size is the supply and return duct now?
Old 07-26-2010, 08:45 PM   #3
Soory for the lack of an answer. Yes there are duct calculators. Get one that also shows the equivalant feet of fittings.
Old 07-26-2010, 08:45 PM   #4
It is a 2.5 ton unit. It conditions a 1500sqft house. I will have to go measure the ducts tonight for you. The return is quite large with 3 large feeds to it, and the supply is huge, with 13 runs coming from it. All is uninsulated so when it reaches the opposite end of the house from the unit it is quite a bit difference in temp, so was looking at insulated flex duct.
Old 07-26-2010, 09:22 PM   #5
Actually.. what measurements should I take? Length of supply from furthest run from air handler? Height and width of supply? What should I measure to get the right measurements? Cause I found a calculator it asks for a few different things with acronyms I dont know.
Old 07-26-2010, 09:30 PM   #6
An old Tradesmen
Rewards Points: 6,148
Are you trying to figure out if your current is big enough/too big. Or are you just going to replace it because its old.
For your current duct. Measure the size of all ducts from the air handler. To the furtherest supply. And a couple of the ones in between. And also do the same with the return.
Old 07-26-2010, 09:31 PM   #7
First I am finding out if it too large. But replacing it because it is old and uninsulated is also a reason. I will measure as required.
How to size a replacement gas furnace B4Dark HVAC 10 06-10-2010 10:55 PM
100A Fuse Panel Replacement Charlie1101 Electrical 4 07-25-2009 03:22 PM
Sizing thoughts moneymgmt HVAC 3 10-28-2007 07:57 PM
