Old 02-16-2012, 01:19 AM   #1
duct sizing
how do i size up duct work on a 10x65 sq. space.. 2 elbows, what would total cfm be?? help.. i just started working and that was my question to figure out.. ive searched every where with no luck.. just need example on how to do this....... thanks
efren is offline   Reply With Quote
Old 02-16-2012, 05:31 AM   #2
An old Tradesmen
duct sizing
Need to know how much air flow you need for the area.
Old 02-16-2012, 10:18 AM   #3
duct sizing
Correct!!!!
Old 02-16-2012, 12:15 PM   #4
duct sizing
You need to learn how to use a ductulator. You can pick these up at a local sheet metal supplier. There are other factors also ie; heat and cooling loads, the number of people for fresh air requirements,static pressure. But I'll assume this is just a test question from your boss. Any supply house will gladly show you how to use one, not hard to do, good luck.
fitter1 is offline   Reply With Quote
Old 02-16-2012, 04:44 PM   #5
duct sizing
Download this ductsizer and have at it
http://www.mcquay.com/McQuay/DesignSolutions/Software
nice n easy is offline   Reply With Quote
Old 02-16-2012, 07:09 PM   #6
as seen on tv
duct sizing
heat gain / loss will need to be known to determine unit size then comes duct sizing
qbert is offline   Reply With Quote
Planning on New duct work..any feedback... kilosos2 HVAC 28 01-26-2011 10:21 AM
Duct sizing C44 HVAC 3 03-23-2009 05:24 PM
Need help Duct Sizing. Cyon HVAC 2 07-23-2008 09:15 PM
1000-1400cfm...duct sizing Swordfish215 HVAC 1 01-15-2007 04:22 PM
duct sizing Stu HVAC 2 12-22-2006 06:36 PM
