Duct Size/cfm - HVAC - DIY Chatroom Home Improvement Forum
Old 10-04-2010, 11:49 PM   #1
Lightbulb
Duct size/cfm
Hi, i'm a journeyman electrician and am new to the DIY site. Now I understand that cfm and duct sizing goes way beyond my HVAC knowledge, but I have a general question. I've been looking at cfm charts and noticed that a 4" round smooth duct will handle about 50 cfm. A 6" duct will handle about 95 cfm. For example, why would a OTR microwave be rated at 350 cfm, if all that it's capable of being connected to is a 3x10 duct? I also told my father in law about this topic, and he said my figuring is bogus. He says if he put a 10 hp blower on a 4" duct, he would get well over 50 cfm. How do these charts measure up? Any kind of enlightenment on the subject would be great!
Thanks in advance,
Jason.
jasonj is offline   Reply With Quote
Old 10-07-2010, 08:44 PM   #2
Come on guys!
Old 10-07-2010, 09:28 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
hey, it's only been 3 days
a lot of the HVAC guys I normally see don't seem to have been around lately.
I'm not an HVAC guy but here is a little bit of what you might be looking for.
saying a duct flows xxx cfm is like saying a hose flows xx gpm. It is only part of the equation. If you increase the pressure, you can make any duct flow more cfm.
here is a statement from another site that should help:
air distribution design takes into account the volume of air to be moved, the desired velocity of the air, and the static pressures developed at the chosen conditions of volume and velocity. without working with all paramaters involved, volume (cfm), speed (velocity), and static pressures (resistance), poor designed system is the final outcome.
so, basically there is no one number that a duct is rated, such as the 4"@50cfm. That is only going to be at a specific pressure. Increase the pressure and you have more cfm, less pressure, lower cfm.
and with your fathers statement; yes, you will get more than the 50cfm with a big blower. You will also have a higher static pressure. Using that pressure, the size of the duct, and the coefficient of friction determined by the material used, you can calculate the actual cfm.
Old 10-07-2010, 09:40 PM   #4
HVAC / Plumbing
see if you can find what your looking for here
http://www.engineeringtoolbox.com/eq...ter-d_443.html
kenmac is offline   Reply With Quote
Old 10-08-2010, 12:28 AM   #5
There is a such thing as too much HP.
In a closed duct system such as a home there is a definite limit to the size of the HP that can be used. Going over that limit a motor can't move any more air despite the HP employed. The blower wheel just spins with out an increase in air flow.
Now granted there are high pressure system that move a lot of air thru small diameter ducts. These are specially designed to do a specific industrial application and so on.
A good example is if a duct system was designed to move 1200 cfm with a 1/3 HP motor, putting in a 3/4 HP motor is not going to three times the air flow .
Motor theory is not something easily explained in everyday language.
hvaclover is offline   Reply With Quote
The Following User Says Thank You to hvaclover For This Useful Post:
jasonj (10-09-2010)
Old 10-08-2010, 12:54 AM   #6
nap
You talking to me?
nap's Avatar
In theory, I can always increase output. It is just that increased HP is not all that it takes to increase that output.
Regardless, I was simply trying to give the OP something to chew on until you HVAC guys showed up. This isn't my thread and I don't want to hijack it. What can you do for the OP?
Old 10-08-2010, 03:27 AM   #7
On a motor chart the cfm plot line and amp draw plot lines meet a point an bisect one another showing that the extra power in HP does not move any addtional air.
Old 10-08-2010, 06:17 AM   #8
An old Tradesmen
Rewards Points: 6,548
The duct chart you are looking at is a FR/pressure loss chart. Not a static pressure chart.
I can put 2,000 CFM through a 6" pipe. It would be at a pressure measured in PSIG instead of inches of wc. But I can still do it(got one at 5 PSIG, and use a 100 HP motor on it ). Its a special application though.
A 3X10 duct can generally handle 60 CFM without excessive noise.
As a range, or microwave vent line. Your not going to get 350 CFM through it unless the blower/fan is capable of working against a 3" static pressure.
The Following User Says Thank You to beenthere For This Useful Post:
jasonj (10-09-2010)
Old 10-08-2010, 10:57 AM   #9
Rewards Points: 280
Hi Jason,
This site helped me with my dyi HVAC project.
http://efficientcomfort.net/jsp/ResDuct_Web.jsp
Earnie is offline   Reply With Quote
The Following User Says Thank You to Earnie For This Useful Post:
jasonj (10-09-2010)
Old 10-09-2010, 12:31 AM   #10
Thanks so much guys! It makes more sense now. I just don't quite understand what that chart would be used for if their are so many variables.
Old 10-09-2010, 12:37 AM   #11
the supplier sized it all for me! I'm building a new house and all the HVAC is up, it went up quite well!
Old 10-09-2010, 05:35 AM   #12
An old Tradesmen
So what size did they say for your exhaust duct.
Old 10-09-2010, 12:09 PM   #13
They sized the whole furnace, hrv, and air conditioning system. I did the bath fans and otr microwave. I went with a 6 inch smooth duct for the microwave and 4 inch smooth for the bath fans.
Old 10-09-2010, 12:11 PM   #14
An old Tradesmen
I'd be leary of their furnace sizing. Unless you sent them a blue print of your house.
Other wise. they just went by sq ft. And guessed. And you could end up with an under or oversized furnace.
Old 10-10-2010, 08:30 AM   #15
I gave them the blue print and they asked all the questions like overhang size, types of insulation used. etc. I went with a 15 kw nortron ecm furnace and a van eer 90h hrv. The house is a 1600 sq ft bungalow with an icf (foam) basement, R-30 walls, R-50 attic, and foam under the basement slab. I can't wait to see the heating bills this winter
Sealing air return duct jd1979 HVAC 8 10-07-2010 08:46 PM
Metal duct or flex? smokey982 HVAC 6 08-06-2010 07:20 AM
adding duct work and outlet jjrbus HVAC 17 05-30-2010 03:13 PM
Return duct "boot or no boot" ads67 HVAC 16 01-10-2009 10:38 AM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 03:33 PM
