Duct Seal Or Spray Foam For Suction Lines? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-26-2012, 05:00 PM   #1
Duct seal or spray foam for suction lines?
Had a contractor replace stolen suction and liquid lines running from the condenser to the coil. Unfortunately, he did a hack job where the lines meet the furnace, it has been leaking condensation on the outside of the furnace do to improper insulation. I called him back, he came out and just added more foil tape and rubber insulation. I have since fixed the insulation problem, running it farther into the furnace and have cut new sheet metal to cover the opening. I am now left with a 1/4 gap (at most) around both lines after running new sheet metal. I am looking for recommendations on the best way to seal this gap. From all recollection, it seems like the duct seal (mastic) is used by most pros, where it is built up thick around the lines. But i am not sure if this is industry standard or just the jobs that I have seen. Anyone familiar with the proper way the seal this gap. Keep in mind this was an added a/c unit by a previous owner and it does/did not have the new suction line fittings like most newer ac/furnaces have.
cjhaas24 is offline   Reply With Quote
Old 06-26-2012, 05:03 PM   #2
John @ OHFS's Avatar
Can you jam more foam insulation into the gap? Then seal/caulk with mastic.
John @ OHFS is offline   Reply With Quote
Old 06-26-2012, 05:17 PM   #3
I could add more insulation, but the gap really isn't the problem. I added the gap after wrapping the pipe so the sheet metal wouldn't cut into the insulation. With duct seal built up around the lines the way I have seen by hvac contractors, in my mind, it should cover the gap no problem. And that stuff is pretty thick, so it wont sag. I was more curious as to which one performs better for the seal or is used as a standard.
I appreciate your post and help!
Old 06-26-2012, 05:58 PM   #4
An old Tradesmen
Rewards Points: 6,456
I prefer to use permagum. Stays pliable. Easily removed if the cover ever has to be removed to clean the coil.
http://www.drillspot.com/tag/permagum-sealing-gum/
Old 06-26-2012, 09:34 PM   #5
Rewards Points: 242
i agree with beenthere, use permagum
hvac instructor is offline   Reply With Quote
Old 06-26-2012, 11:08 PM   #6
Perfect! Thanks guys! That was exactly what I was looking for.
Old 06-26-2012, 11:51 PM   #7
cork tape trumps permagum.
hvac5646 is offline   Reply With Quote
Tags
a/c lines , duct seal , insulation , spray foam , suction lines
Spray foam insulation troyce1 Insulation 12 12-14-2014 07:30 AM
stone coated steel and spray foam insulation waternut Roofing/Siding 2 01-15-2011 07:36 PM
Tiger Foam On Duct Work atw58 Building & Construction 1 04-25-2008 11:25 PM
How Do I Install New Duct Lines For My Finished Basement? luweee HVAC 17 01-12-2008 04:01 PM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 03:33 PM
