Old 01-06-2009, 08:10 PM   #1
Duct pipe question
Since the ducts are made by inserting into each other, I was wondering if you build the whole duct and then insert the appliance?
Or could you leave a straight section both ends crimped, and then use a straight section and snap it close to complete the duct?
DIYGST is offline   Reply With Quote
Old 01-07-2009, 10:52 AM   #2
Duct pipe question
Either way. Sorta depends on how easy it is to move the appliance
If the run of duct is short, it may be hard to do it the other way (you have to depend on being able to push the ducts apart enough to insert that last piece).
Garasaki is offline   Reply With Quote
Old 01-07-2009, 12:03 PM   #3
Duct pipe question
You could also consider a draw band that is basically a clamp that you can connect two sections with. Can't be used on exhaust venting though.
SKIP4661 is offline   Reply With Quote
More On This Topic
Hi this is Fernando we are here with Expert Village and we are going over a sprinkler system and particularly we are going over laying out your pvc before you actually get started. It is very important that you take the time to layout your materials as... Read More »
How a Sprinkler Head Works
How a Sprinkler Head Works by Expert Village
Hi I'm Fernando with Expert Village going over how a sprinkler head actually works and as you can see this sprinkler is connected to the pvc piping. When the pressure comes from the valve which is the water rushes in and fills up the piping it then goes... Read More »
Hi this is Fernando we are here with Expert Village and now we are going over some of the problem areas that you may have. Here you see a curve contour around a cement post this is problematic because normally like in the back yard we have a huge... Read More »
Hi this is Fernando we are here with Expert Village going over how to maneuver around certain obstructions like cement. Here you could see we are here next to a fence and do to what is in the dirt we are not able to have a clear cut obstruction view of... Read More »
Hi this is Fernando and we are here with Expert Village and again we are going over a watering system and particularly we are go over how much material you need to buy. Now out of the sprinkler, pvc piping, connectors how do you figure out what you need... Read More »
Noobish Duct Connection Question jonathan03 HVAC 4 12-30-2008 08:52 AM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 06:40 PM
Cast iron and rusty pipe question snowens Plumbing 2 07-27-2008 11:07 AM
Question Pipe broke in/under slab Evnldr Plumbing 6 06-25-2008 08:28 AM
grounding to water pipe question eastvantrading Electrical 6 12-20-2006 10:49 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
