Old 01-05-2012, 09:00 PM   #1
Duct part identification
Can someone please tell me the name of the duct work piece that goes from a 4" round to a flat and back to a round. This piece is to create room to get other piping past the duct work. Also a concise explanation of how to install it would be nice as well. The ones that I currently have in my house just seem to be attached with a screw.
GravityMaster is offline   Reply With Quote
Old 01-05-2012, 09:05 PM   #2
I'm Your Huckleberry
Square to round. This is located in line in a duct? Can you take a pic?
Doc Holliday is offline   Reply With Quote
Old 01-05-2012, 09:30 PM   #3
it not a very good pic but I need another one of these
Uploaded with ImageShack.us
Old 01-05-2012, 09:36 PM   #4
Missouri Bound's Avatar
That's actually 2 fittings with a short length of square duct between. Take the picture to any good plumbing / heating supply or one of the big box stores. And be careful with the advice you get at the big box stores. And measure everything, length and width of the square duct and size of the round.
Old 01-05-2012, 09:42 PM   #5
sorry brain dead on this one...ben
Old 01-05-2012, 09:54 PM   #6
MarginallyQualified
Is there a tee fitting or tap in that as well?
It looks like there is something other than plain OSB immediately above it.
Old 01-05-2012, 10:27 PM   #7
REP
If that is 6" round pipe then what you have is two 12x3x6 stack boots with a piece of 12x3 1/4 stack inbetween them.
It looks like the top piece is hand made but it could be replaced with a 12x3x6 boot.
REP is offline   Reply With Quote
Old 01-05-2012, 11:29 PM   #8
I dont know much about air flow, but common sense tells me that the duct in the picture would not be optimal for air flow ... looks to me like it would lower the pressure in that area, then have to squeeze the air back into the round duct. Seams to me that the static pressure there would not be so good. I could be wrong....
bobinphx is offline   Reply With Quote
Old 01-05-2012, 11:34 PM   #9
Yep, you are wrong. The 6" duct is approx a 27 sq. in. opening......the 12 X 3 is.....well you know....36 sq in.
Old 01-05-2012, 11:40 PM   #10
thanks for the clarification!!!! and I do mean it. I am just trying to learn and I appreciate the correction.
Old 01-05-2012, 11:43 PM   #11
You are very welcome.....and I appreciate your attitude.
brown liquid oozing from duct.(??) noquacks HVAC 12 08-18-2011 06:24 PM
Planning on New duct work..any feedback... kilosos2 HVAC 28 01-26-2011 10:21 AM
HVAC Duct Tools beertestr HVAC 0 11-27-2009 08:35 PM
flex duct termination issue LanterDan HVAC 2 02-12-2009 06:59 AM
Can I use duct tape? Dusty HVAC 2 09-27-2006 09:28 PM
