Old 08-01-2010, 12:18 PM   #1
duct moisture
I found one of my flex supply ducts has water on it, enough that it accumulates and drips off. Don't know how long this has been happening.
What are the potential causes? I don't have much access to the duct work(no attic) but am trying to find out if this is happening in other areas. There is no moisture on the main trunk as it exits the unit, nor on the 2 short supplies off the main in the HVAC closet.
Thanks for comments and opinions.
7echo is offline   Reply With Quote
Old 08-01-2010, 02:50 PM   #2
An old Tradesmen
duct moisture
Is there an air leak near the area where the moisture is? If so, thats your cause.
Could also be the insulation in that area of the flex is damaged or missing.
Old 08-01-2010, 05:24 PM   #3
duct moisture
I am checking for leaks, but this is a tight spot. From what I can see, the insulation is good.
Old 08-01-2010, 06:06 PM   #4
An old Tradesmen
duct moisture
A small air leak is all it takes.
Old 08-02-2010, 07:20 AM   #5
duct moisture
What ways can I check for a leak? I can't get to the area where the flex is tied into the trunk without tearing out drywall. I would like to avoid that if possible.
Old 08-02-2010, 07:30 AM   #6
An old Tradesmen
duct moisture
The air leak would be very near to the area that has the condensation.
Basement Moisture, what's this? bergerdude Building & Construction 1 06-11-2010 02:27 PM
adding duct work and outlet jjrbus HVAC 17 05-30-2010 03:13 PM
Duct work in garage. flashme18 HVAC 1 11-08-2009 07:29 PM
Flex Duct Advice ssporty21228 HVAC 4 07-23-2008 09:28 PM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 03:33 PM
