Duct Leaks - HVAC - DIY Chatroom Home Improvement Forum
Old 09-05-2011, 09:30 AM   #1
Duct leaks
What's the best way to find leaks in ductwork? My ducts are in the attic and I'm pretty sure I have a or even some leaks, what's the best way to find them so I can repair?
Pipelayer31 is offline   Reply With Quote
Old 09-05-2011, 10:06 AM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Physically get into the attic and visually inspect for leaks. The attic will be much hotter than the the cold air flowing through the ducts so have the system on and in cooling mode and literally feel around the ducts for any possible leaks, especially where they connect at the plenum and at the registers.
Doc Holliday is offline   Reply With Quote
Old 09-06-2011, 03:20 PM   #3
REP
The cheapest thing I know of is getting some of those incense sticks that give off smoke as well as scent.Light it,and hold it all around each duct connection.Where you see the smoke flutter away from duct (while the fan is running) on the supply side is an indication of a leak.On the return side,the smoke is likely to be drawn intoward the leak.
Good luck.
REP is offline   Reply With Quote
Old 09-07-2011, 10:34 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,130
Blower door test will also indicate duct leakage for ducts that are outside the envelope.
Old 09-08-2011, 02:37 PM   #5
I use my lighter
Nothing some versabond won't fix
In my area, Washington dc, they are requiring blower door tests on almost everything and we end up sending someone around "seek and destroy" style all over the place
Dr.HVAC is offline   Reply With Quote
?an Insulated Flexible Duct - half attached and half unattached ? tran Roofing/Siding 2 06-21-2012 06:25 PM
My Duct Sealing Project Cakemeister HVAC 6 06-13-2011 11:45 AM
Planning on New duct work..any feedback... kilosos2 HVAC 28 01-26-2011 09:21 AM
Metal duct or flex? smokey982 HVAC 6 08-06-2010 06:20 AM
HVAC duct leaks rainwater williwaset HVAC 3 04-22-2010 01:22 AM
