Duct Help - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-19-2008, 04:07 PM   #16
An old Tradesmen
Rewards Points: 7,376
The further away from the register the better for noise reduction.
In case you have to cut flow back real far on one of the supplies.
Old 12-19-2008, 05:04 PM   #17
OK that makes sense. Thanks for the info.
So I'll run the start coliers from the plenum, then the damper, then a wye 12x7x10, one damper on the 7 running flex duct to the register, then a wye on the 10" from 10" to (2) 7"s with dampers on each of those then flex duct to the registers. That will be (3) 7's from the one 12" off the plenum. Does that sound good?
I'll do the same for the other 12" but the first wye will have a 5" comming off one side and a 10" then spliting to the (2) 7's.
integlikewhoa is offline   Reply With Quote
Old 12-20-2008, 05:39 AM   #18
An old Tradesmen
Your zones are a bit small.
But, since your using the W8835, you should be ok.
Make sure you set it up to never go to second stage unless 50% of the zones are calling.
Old 12-21-2008, 02:19 AM   #19
Thanks I'll look into the 2nd stage deal. I'm not sure I know how to do that but I can read. Also to let you guys know tonight Is my first night with heat in the house. I'm not finished, but almost. Still need to wire the dampers, rap the metal ducts with insulation, and finish up some wiring, but it sure feels good to have heat in the house. Got my clean effects and UV filters going, just need to install the truesteam and then I can move to the A/C compressor and lines.
Thanks for everything. Also on the manual dampers, I ended up getting some of the plates and KD pipe and made my own setup to save some cash.
Old 12-21-2008, 03:37 AM   #20
An old Tradesmen
On the TrueSteam.
Make sure it controls the blower after the call for humidity ends.
Otherwise, you'll end up with steam going into the duct work and condensing.
The 50%, is in the installers manual, its easy to do.
Old 12-21-2008, 11:49 AM   #21
On the TrueSteam.
Will do thanks for your helpful info. I need to still run my water and drain line from the crawlspace below the house to the attic.
Old 12-21-2008, 03:24 PM   #22
An old Tradesmen
If your area has temps below 32, don't install a humidifier in the attic.
During a power failure at outdoor temps below 32, the humidifier and water pipes could freeze, and burst. Causing 1000's in damage.
The Truesteam can be remote mounted. If you have a closet near the furnaces location. I believe its 20 foot max for the hose for remote installation..
Old 12-21-2008, 04:20 PM   #23
Yes it can be remote mounted up to 20ft, I'm good here I live in Los angeles or the out skirts and we dont have freezing problems here. 40's is all we see, maybe 2-3 times a year. I get cold when it hits 65 outside. I think I'm spoiled.
Old 12-21-2008, 04:25 PM   #24
An old Tradesmen
LOL... It ain't cold out until the dogs water bowl freezes.
I keep his water bowl inside.
Furnace install in attic - Duct configuration hartkem HVAC 6 11-08-2008 05:46 PM
Flex Duct Advice ssporty21228 HVAC 4 07-23-2008 08:28 PM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 02:33 PM
Modifying existing duct work Thurgee HVAC 3 04-05-2007 09:35 AM
1000-1400cfm...duct sizing Swordfish215 HVAC 1 01-15-2007 03:22 PM
