Duct Formed In Slab - HVAC - DIY Chatroom Home Improvement Forum
Old 10-01-2011, 03:53 AM   #1
Duct formed in slab
My son is looking at purchasing a home where the duct work is formed into the slab. I looked under the furnace there doesn't seem to be any type of lining material. It looks like it was just formed before they poured the slab. I can see problems with this. Mold probably my main concern. Hard to add additional runs. Mildew odors. Any other issues to be concerned about?
Another concern location of furnace. Middle of the house in a closet water heater next to it. Combustion air supply?
Can a down flow furnace be converted to a up flow?
My fix for this would be to run everything in the attic. Probably not a cheap fix but well worth it.
Greatly appreciate anyone's input. Thank You!!
reckless is offline   Reply With Quote
Old 10-01-2011, 06:22 AM   #2
Rewards Points: 1,216
Yes you can remove the counterflow and fill the hole with concrete, install a up flow heater and new ductwork in the attic or you can install a unit in the attic by hanging it from the framing, or you can put a baseboard system hot water heat in. All need to be sized for the house and a good design..
COLDIRON is offline   Reply With Quote
Old 10-01-2011, 08:53 AM   #3
Thanks for responding! Any know issues with having the duct incased in the slab? I don't want to see him get stuck with a house then find out he has to change the heating system. Thanks
Extending Patio Slab and adding a cover Jeoroc24 Building & Construction 5 04-12-2011 11:16 AM
Planning on New duct work..any feedback... kilosos2 HVAC 28 01-26-2011 09:21 AM
raised slab foundation tclark Building & Construction 6 01-07-2011 08:10 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 12:23 PM
