Old 12-12-2010, 07:24 PM   #1
Duct in exterior wall
I would like to put a wall mount register in a new addition. location dictates that it will be in an exterior wall that would require running the duct from the basement between the joists, up through the bottom plate in the wall in question - thus about a foot of the 'duct' would be formed by lining the inside of the studs and wall sheathing with fiberboad then out to the register. Is this 1) legal 2) adviseable? I don't like walking on the registgers if floor mounted and I read a few studies that showed that wall mount works better in my Utah climate (happy medium between optimum floor mount and high wall mount for varying hot and cold seasons).
Thanks,
kb
kbennett is offline   Reply With Quote
Old 12-12-2010, 08:22 PM   #2
An old Tradesmen
Thanks,
kb
You install a wall mount in an outside wall and you get a poor distribution in that room.
Floor mount works better. Keeps the warm air at the outside wall. Makes the house/room feel much better.
Planning on New duct work..any feedback... kilosos2 HVAC 28 01-26-2011 10:21 AM
Sealing air return duct jd1979 HVAC 8 10-07-2010 08:46 PM
Metal duct or flex? smokey982 HVAC 6 08-06-2010 07:20 AM
adding duct work and outlet jjrbus HVAC 17 05-30-2010 03:13 PM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 03:33 PM
