Duct Elbow - HVAC - DIY Chatroom Home Improvement Forum
Old 12-15-2009, 10:27 AM   #1
Rewards Points: 640
duct elbow
So I need to create a U shaped duct for a bypass on my furnance.. I have an elbow joint duct it ways 90 degrees but when I put two straight pieces on it, its no where near square... am I missing something here? why isn't 90 degrees square? is this the way they all are or is this just a bad elbow? I can rotate one part of it, but it doesnt seem to help much in making it more square... should another part rotate somewhere to make it more? what am I missing? thanks!
BlueBSH is offline   Reply With Quote
Old 12-15-2009, 10:29 AM   #2
the Musigician
DangerMouse's Avatar
need more input... size and type duct?
got any pics of what you're doing?
that almost always helps.
DM
Old 12-15-2009, 10:35 AM   #3
Rewards Points: 640
DM
6" Diamater standard alum heat duct
I am running behind the furnance from the return to the supply which has a humidifier which needs to connect to the return via this bypass duct its a 6 inch duct connection on the humidifier and I have a 6 inch connector already on the return with a damper on it to close it off when needed... just need to make a connection between these two, which is a U like shape just with short straight ends to a 90 degree elbow then in the middle a 4 to 5 ft straight duct
something similar to this picture http://z.about.com/d/homerepair/1/0/...ier3_noted.jpg
but the elbow does not go 90 degrees.. it points away from by like 10-15 degrees where I need to be...
Old 12-15-2009, 10:52 AM   #4
the Musigician
if it's EXACTLY like that corner shown in that pic, those sections swivel within themselves to align properly.
is this the case?
DM
Old 12-15-2009, 10:56 AM   #5
All 4 joints of the elbow should turn. Try a drop of oil on the joints and if that doesn't work take it back for a new one.
Old 12-15-2009, 10:57 AM   #6
Rewards Points: 640
is this the case?
DM
I can get one part of the elbow to swivel, but it will never move to a place that makes it a good 90 degree angle should only one part move? because thats all I can get to move is one end piece that has the ribbing on it
Old 12-15-2009, 11:03 AM   #7
the Musigician
what he ^ said....
all the sections should swivel.
DM
Old 12-15-2009, 11:06 AM   #8
Rewards Points: 640
what he ^ said....
DM
I'll give it a try over lunch and see if I can get them to move with some oil drops or something... bugged the heck out of me last night when only one section would move...
Old 12-15-2009, 04:52 PM   #9
Old Newbie
If the elbow is out of round (squished even slightly) the sections won't turn.
tinmanrob is offline   Reply With Quote
Duct work in garage. flashme18 HVAC 1 11-08-2009 07:29 PM
Return duct "boot or no boot" ads67 HVAC 16 01-10-2009 10:38 AM
Flex Duct Advice ssporty21228 HVAC 4 07-23-2008 09:28 PM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 03:33 PM
1000-1400cfm...duct sizing Swordfish215 HVAC 1 01-15-2007 04:22 PM
