Duct Disconnected In Hard To Reach Area - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-25-2010, 02:50 PM   #16
Rewards Points: 292
Originally Posted by beenthere View Post
Yep. Nothing like being itchy all day after working in an attic.
Been, do you wear a dust mask or respirator when you go up there? I have to put one on if I just go up for a minute to check my antennas. If I don't I get itchy lungs.
veesubotee is offline   Reply With Quote
Old 08-25-2010, 03:08 PM   #17
fabrk8r
fabrk8r's Avatar
The flex duct can be cut and then reconnected using the proper diameter "coupling". A local sheet metal shop can make a coupling for you if you give them the diameter. It will be a round sleeve about 6" long with at least 1 raised bead in the center to add rigidity, but it really works well for wiremold flex to have 3 beads. 1 bead in about 1-1/2 inches from each end will give the panduit strap a place to rest without being pulled off.
Panduit strap is like a large zip tie that is applied using a special tool that pulls it very tight around the flex and cuts it off at the same time.
You can use screws to fasten to the collar, but I wouldn't recommend it.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-28-2010, 05:55 AM   #18
Rewards Points: 1,216
I recommend following post #10 first.
Take register off try to look in the attic from there .. use a mirror if necessary. Then figure out the next step how to reach and or connect the disconnected flex duct.
Let us know how you make out .
COLDIRON is offline   Reply With Quote
Tags
attic , duct work , hvac , vents
Return Air Vents stubits HVAC 149 04-21-2010 04:50 PM
flex duct termination issue LanterDan HVAC 2 02-12-2009 05:59 AM
duct work framing kama Carpentry 4 11-15-2008 12:40 PM
Modifying existing duct work Thurgee HVAC 3 04-05-2007 09:35 AM
help Chuckman Off Topic 8 06-15-2006 10:06 PM
